Question about HP Hewlett Packard Pavilion A6200N PC Desktop
HP pavilion a6200n cd not recognizing any CD/DVD disk. Any suggestions?
  • 358 Answers
There are three possible reasons for this, the first one is that, your CD/DVD lens might have become weak, and therefore might need to be changed, or if its just dirty, you might just need a lens cleaner.
The second reason is that, it might be that the CD you are trying to read is bad, dirty, or not properly burnt...in this case, you might need to clean the surface of the CD properly then re-insert it.
The third reason is that, your CD/DVD Drive might be having a conflict within the OS. What I would suggest in this case is that, Power up your system, then when the system boots, just right click on my computer, then properties, then select the hardwares tab, then click on device manager.
When you get to device manager page, try and locate DVD/CDrom Drives, then click on it, if your drive is there, then just right-click on it, and select uninstall, and after this, on that same page, click on 'Actions', and select "Scan for hardware changes". But if its not there. Just click on the "Actions, and Then select "Scan for hardware changes".
This should automatically place your CD/DVD drive back inside your My Computer page. After this, try the CD or DVD again.
Hope this helps you out.
Posted on Apr 25, 2010
Optiarc DVD RW AD-7201S5 drive does not read lightscribe discs
get a new DVD drive, up grade.
VISTA OR W 7 IT IS.
the problems
HP a6642p (SUPER OLD DESKTOP)
CIRCA 2010.. ?
does device manager show, its OK?
HAVE you gone to HP.com and loaded the drivers for this yet?
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-a6600-desktop-pc-series/3793920/model/3825363
Apr 05, 2017 | HP LightScribe dvd640i (DVD640I)...
HP Pavillion a6200n PC cd not working, but the DVD does work. When I put a cd in, it will not work. When I click on the drive, it asks me to insert a cd, it closes but does not play. The DVD works when I...
Your CD drive has an internal failure which is usually the laser head. It would be cheaper to replace the drive or use your DVD drive to read CD's then to have the laser head replaced in the CD drive. The disk tray motor system is not connected with the read write system in the drive and the tray ejecting or loading a disk is not an indication of the health of the drives logic system or laser head.
May 20, 2010 | Computers & Internet
Laptop dvd doesn't read disks
follow these steps:
start-my computer-right click-manage-device manager-cd/dvd drives -click update driver then restart your pc and try it .
Feb 01, 2010 | HP Pavilion dv6000z Notebook
Can't use cd/dvd player - computer doesn't recognize it
try to boot the computer using cd. like you trying to install windows. if it read the cd to get into the windows setup, then cd drive is good.
1st make sure you set the option boot from cd first in the bios.
2nd place a windows setup into the drive.
3rd save and exit the bios.
4th if it ask you to press any key to enter setup then the cd drive is good.
maybe u have a windows problem, try to reinstall windows, that the easy way.
Aug 28, 2009 | HP Pavilion dv2000t Notebook
Hp pavilion zv6000 wont recognize dvd+r
Hi Terry,
The answer is pretty simple, the ZV series is about 4 years old, back then DVD manufacturers decided which formats they would support as it was too expensive to make desktop drives, let alone, laptop drives that supported all formats. That drive only works with DVD-R and I believe DVD-RW. If you want to burn other formats, the laptop will only support them if you add an external drive of a newer make.
Note: Virtually all current models support ALL DVD formats and many support BluRay as well.
Hope this helps,
Chris
Jul 07, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Dvd plays initially and then stops
It could be the drivers for CD/DVD.
The best way to troubleshoot this is right click on computer, select manage. A new window will pop up, in that list select device manager.
Look in the list for CD/DVD drives and click on the + sign next to it, when the tree opens right click on the CD/DVD drive and select uninstall, then restart the PC.
This method will hard reset the system and force windows to load the default drivers for the CD/DVD upon restart. Hopefully this should resolve your problem.
If not please post back.
Good luck
Jun 15, 2009 | HP Pavilion DV2740SE Laptop
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
My DVD/CD player does not recognize the CD in the tray
Try cleaning the laser lens with a q-tip in a circular motion. Make sure none of the cotton fibers are left behind.
let me know what happens. If it doesn't work I'll suggest a few more tips.
Feb 26, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
HP Tochsmart DVD-RW drive not playing cd's /dvd's
The best player is Video Lan Controller (VLC) is plays everything.
You need the RIP command as you have not a data disk but a multimedia disk (.CDA) file.
Jun 13, 2017 | HP Pavilion TX2000Z Tablet PC
DVD Drive not working properly
Try cleaning the drive with a cleaning disc (purchasbale at most electronics stores like Best Buy or Circuit City). If that doesn't get it up and running, it'll need to be replaced.
Jan 29, 2008 | HP Pavilion dv6000z Notebook
HP Hewlett Packard Pavilion A6200N  PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
