Question about Acer eMachines 520-2890 Notebook
Laptop has just been dropped now it freezes on boot, i have no cd for it to try recover please help
  • 358 Answers
From what I can deduce here, it seems that you the hard drive probably has had a bad sector on it.
Or there is a problem with the read/write head inside the hard drive as a result of the shock caused by dropping it.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, get an external hard drive case, (remember to choose the approriate type (i.e either SATA or IDE) then connect it directly to another system, through USB 2.0 this time around.
After it is being detected by the system, Perform a scan on it by:
Right-Clicking on the icon representing your hard drive, go to properties, then select tools, then select check for errors on hard drive.
After performing this, if it successfully finishes the repair, I would advise you to backup All your data from it, in case it fails later.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, "Again" I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Apr 25, 2010
How can I recover my password after resetting my dell pc inspiron 15 please?
look on google for 'password reset cd', or 'hiren's boot cd' (from another computer, download it, and burn to cd) boot dell with it. see the utilities to recover administrator passwords.
Jul 29, 2014 | Computers & Internet
I dropped my laptop now when i turn it on i get error message saying tyhe kernel is missing or corrupt.i've tried booting from the cd i got and nothing, when i try starting in safe mode windows starts...
Think the worst.!! and accept you have lost all!
Do a restart, on accessing push F8. safe mode menu's.
Click recovery, follow in structions. hopfully this should work, you pick when you wish to recover to which date.
Should this be sucessful, save/copy your iportant docs and keep them up to date.
If this fails to recover, then you have lost all!
Restart, F8 choose Factory Recovery this will formatt all and reinsert a fresh win system, that is of course that there is no damage caused when impcting on the ground.
Hope all works out well?
May 12, 2011 | Computers & Internet
Samsung mini laptop n148. Windows Xp pro is installed. I installed Norton Ghost v 15 and made recovery for my drive C. When I boot with the Norton Ghost recovery cd, it boots well untill it reaches 20% of...
It sounds to me that unfortunately you have an error on your recorded CD and there will be nothing you can do to repair that.
The installation of Norton should not cause the problem itself an error on the hard drive will usually cause that problem.
Oct 23, 2010 | Samsung Computers & Internet
NO HDD RECOVERY AREA !
first boot pc, then right before windows would start, press either F2 or F8,, I think it's F2, this will bring you to bios settings, look for bootup device options, Set cd-rom as first bootup device, then Hard drive as second device, Then save settings, insert recover cd, then restart pc, it will immediately boot up your recover cd or windows disc
Oct 06, 2009 | Computers & Internet
How to i recover my acer netbook from a cd if it has no cd drive?
ok you need to insert the disk, then shutdown the laptop then turn it back on, the first screen that shows up should say the brand name and have some words at the bottom of the screen saying press f12 for setup and so on, as soon as this screen appears press the pause button on the keyboard so the screen freezes, now read the options at the bottom and select which ever button opens the boot menu it will be one of the f something buttons, this will open the boot options menu select boot from cd rom drive and that shud start up the recovery program that will guide you step by step. hope that helps
Apr 07, 2009 | Acer Aspire One Netbook 8.9" Notebook
Dropped laptop
Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Another more intense diagnostic program is located on a Dell CD that you should have received with your laptop. Look for one that has “Diagnostics and utilities” listed under the “Contents”. You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the “Run the 32 Bit Dell Diagnostics”.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 31, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
BIOS Password reset on Toshiba A135-S2276
Use a boot disk such as, the Ultimate Boot CD or the Ultimate Boot CD for Windows if you don't need a BIOS password. If you do, try Toshiba.
Oct 20, 2008 | Toshiba Satellite A135-S2276 Notebook
I have a new samsung NP-R60Y laptop running on vista home premium and it keeps freezing up, this could have in the first 10mins of switching it on or within 3hours, tried removing recent software and...
If you have the recovery cd, boot your laptop with the recovery cd in it and follow the screen and recover your system to factory settings than it should be ok.
Aug 19, 2008 | Computers & Internet
450sx4 freezes half way thru setup
E-mail CHID: 5736 So basically it freezes trying to intialize the setup. ... try rebooting the computer into safe mode and run the setup through safe mode.
Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Gateway 450SX4 Notebook
Acer eMachines 520-2890 Notebook Logo
328 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
