Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
I can't get mines to charge correctly, can you help me?
  • 608 Answers
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Posted on Apr 25, 2010
My car engine shuts off when i put in reverse.
working right means zero
we know that, or you;d not be here, LOL !
the car has an automatic, mines 5speed stick
i sold min, suzuki is dead car company here .....
my wild wild guess
charge system died
battery died driving, as all do ,like that
then instead of changing it ,you bought a new battery
and not this repeats.
what is the problem,, charge system failure
why not charge the battery
drive to any shop and get it fixed correctly
Jan 04, 2016 | Suzuki Grand Vitara Cars & Trucks
How do I know if my purchase is charging? Keeps showing a black screen after a few moments of the green tube thingie
I figure that you've got the correct adapter for your device...
and that you not have plugged it the correct way. The device I've got has a micro USB cable, and it is hard to tell which way is "UP".
Mine has a white dot on the "top" (same side as the screen).
IF you look closely, you will find that the cable has a "wide" side and a "not-so-wide" side, make sure the cable goes in the right way.
IF there seems to be a very loose fit, then maybe you've got the wrong cable (mine gets mixed up with my phone's cable).
When the cable is in, correctly, my device turns on and starts charging...
Hope this helps you.
Topbarhive
Dec 03, 2014 | Tablets & eReaders
Hi i have an HP Elite Book 6230p,my laptop stop charging recently, i was charging it and i removed my charger plugged in another charger of lower current rating it worked well for a while, but when i...
Nice books, have many. 8540s./. better.
i can not decode this post.
sorry
does it run with no battery and the correct pack
mine has 10 options new the i7 and the fast video card suck huge power and mine needs a 100watt pack, the 65w on mine is HOPELESS. see?
run the correct matching pack,
step 2 a new battery, i keep 2 good ones all the time
on Vacation, id not be wanting to find batteries 3000 south of here, ever. (south of the boarder)
test with no battery
then with correct power pack (the charger is a chip inside the pc and in this 19vdc pack its only a power pack pure DC.
then try a new battery ,
if you read your service manual at HP.com
it tells you all packs used and why, and the match.
sure does.
and varies by OPTIONS DAY1. in all case
unless upgraded like mine, is, and sucks max amps mine does.
Jul 03, 2017 | HP EliteBook 6930p Notebook PC
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
NS-DCC5HB09 High Definition Flash Media Camcorder: mine wont turn on and i dont have a charger!!! Hel...
You should be able to recharge this unit by connecting to your PC and charging through your USB connection.
If your battery is faulty or unable to recharge, here's a replacement battery that's available:
http://bestbuy.partsearch.com/GetModel.aspx?MfgName=Best+Buy+Company+Incorporated&BrandName=Insignia&ModelNumber=NSDCC5HB09&Page=1&SortBy=brandname&SortDirection=asc
Just about any AC to USB charger will work to recharge this unit, so if you have an iPod with the iPod wall charger, use the correct USB cable with the wall charger and you will be able to recharge the battery in the camcorder.
Hope this helps!
May 11, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
LG Vu Wont chrge correctly
Your charging port is probably going bad. It seems to happen fairly regulary on the lg VU
you can get it repaired or get a workaround external battery charger.
Check out the following link for your options.
http://www.chargemyphones.com/lg-vu-wont-charge/4/
Jul 02, 2009 | LG Vu Cellular Phone
Meter Explanation
You are correct on all accounts. A high number means you dying battery is sucking more juice from the Schumacker. A low number means the battery is not as thirsty. That's how I always think of how to read the meter on mine. Slow charge is a better, deeper charge. The quick charge will get you going, but you should maybe follow it up using the normal mode - car alternator and prolonged drive time. I never use quick charge, personally.
Apr 26, 2009 | Jeep Grand Cherokee Cars & Trucks
Ipod nano
I had the same problem and mine kept crashing when attempting to charge. I had to send mine away to Apple and they sent me a new one.
Sep 29, 2008 | Apple iPod nano
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
307 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
