The power button flashes when turned on and sometimes takes up to ten minutes before the moniter will come on.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 26, 2010
Power Switch comes on but moniter goes back to sleep.
use external monitor to setup internal monitor setings
Nov 10, 2012 | eMachines T3508 PC Desktop
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
How do you star a 98 chavy malibu with tha anti theft light on
Here is what you do. make sure the battery is fully charged cause you dont want it to go dead during this process or it wont work. step down on your parking brake pedal and leave it down. this will keep the headlights off during the process so the battery wont go dead. turn the ignition key like you were going to start the car then leave the key in the on position. you have to leave the key in the on position for ten minutes. during the ten minutes you will see the anti theft or security light flashing or the display in the instrument cluster. when the ten minutes are up the security light will go out. once the light goes out attempt to start the car. if it doesnt start turn the key all the way back to the off position count to three then attempt to start the car then leave the key in the on position another ten minutes till the light stops flashing again. sometimes it takes up to three ten minute cycles to reset the antitheft system. so basically you do the same thing three times leaving the key in the on position for ten minutes each time so it will take approximately thirty minutes. sometimes it will work on the first try though.
Oct 31, 2009 | 1998 Chevrolet Malibu
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
Every few minutes brings up box 'No Signal'. Sometimes when powering on ACER logo thing takes a few minutes to disappear.
I have a Acer moniter too. Seems like you have a loose VGA cable or not enough power going into the video card
Jun 04, 2009 | Acer AL2423W LCD Monitor
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
