Question about Siemens Washing Machines
How do I stop my Siemens xlm 1600 beeping at the end of the cycle??
4 Suggested Answers
SOURCE: SIEMENS XLM 1600 (WXLM166AGB) MACHINE
If water is being dispensed from both sides of the detergent tray, dismantle washing machine and remove top plate of the detergent tray and clean thoroughly. Water overflows from both sides during the rinse cycle to add softener to the rinse. On our washing machine it was blocked. During the service it was changed but can be washed out to solve problem.
Posted on Sep 15, 2008
  • 190 Answers
SOURCE: SIEMENS XLM 1600 WON'T GO INTO SPIN CYCLE
Dear customer,
                     When the spin cycle doesnt occur the most recommended steps are
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission.
  You can click on the highlighted words to get details abt the checking procedure..
Plz rate this solution.. thank you..
Posted on Apr 09, 2009
SOURCE: siemens xlm 1600 leaving scum
Had the same problem with our Siemens XLm1600. The problem is that you are using washing LIQUID.
Change to a powder (particularly a biological one) and you'll be ok...
Posted on Jul 14, 2009
My washing machine is leaking a lot of water during a cycle - underneath in the front. Could there possibly by a back log of water? I have drained it, but it's a lot of water.
You will need to open up the front or rear panel and inspect the hoses before and during operation to see where the leak is. There are many Youtube videos on how to remove the panels. Good luck!
May 18, 2016 | Siemens Washing Machines
Siemens xlm 1400 will not rinse clothes, it makes noise but the drum will not rotate eventhough it will turn by hand.
your motors drive brushes need replaced
so look to use the model number in EBAY
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xxlm+1400+brushes.TRS0&_nkw=xlm+1400+brushes&_sacat=0
i used the search string
'xlm 1400 brushes'
and they are quite easy to replace..
it may do a whole wash cycle and count down etc just wont spin or move the drum with heavy water laden clothes
goes eeeeeeeheheeheh but no drum rotate
so
you can drain the machine only
lay the machine down with the soap drawer away from the ground
then it wont leak
two screws and one power clip removes the brushes
from the main motor {the one with the belt that drives the drum}
their are two brushes one each side
so 4 screws
and replace both ..
so...
good times
let us know the size of the brushes left
they should be like new 2.5" - 3" long
if they are less then 1.5" replace them
this is the issue
the main advice is not to use it just now
till you check the motor brushes
as this type of fault can further damage the motor
so .. dont use it till you check / replace the brushes as the intermittent contacting will damage the motors stator {the bit the brushes make contact with}
Aug 19, 2014 | Siemens Washing Machines
Hello, I have a Siemens 1600 WXL166AGB (1600 XL) washing machine. there is a humming while still washing and then it stops and beeps on drain, but not every time. have cleaned out filter, impeller turns,...
Sometimes the impeller can wear so that it is pulled to one side and jams intermittently. Try removing the pump and running it outside of the machine to see if you can catch it misbehaving. Or just replace the pump.
Sep 13, 2013 | Siemens WK61420GB Front Load Washer /...
Spin cycle will not work on siemens xlm 1400 and filter has been cleaned what to do
If the spin cycle is not working, it could be several things. How is it not working? If it won't do anything, i.e. doesn't turn, then I would suspect the transmission since the spin cycle is the high side of the transmission. If it spins but does not take the water out of the unit, then I would suspect, either the pump or the timer.
Good luck and have a great day!
Jun 09, 2011 | Washing Machines
Dear customer,
  8. Test the motor
Apr 09, 2009 | Siemens Washing Machines
SIEMENS XLM 1600 (WXLM166AGB) MACHINE WILL NOT TAKE IN SOFTENER FROM DETERGENT TRAY
Aug 28, 2008 | Washing Machines
Siemens xlm 1600 leaving scum type marks on washing
May 10, 2008 | Washing Machines
Washing Machines Logo
279 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
