Question about 3Com Baseline Switch 2948-SFP Plus 48-Port Gigabit (3CBLSG48-US)
3CBLSG48 Login password - 3Com Baseline Switch 2948-SFP Plus 48-Port Gigabit (3CBLSG48-US)
My apple lap top keeps asking me for my key chain password, what is this?
Try using the password for the user you are logged in with? J
Aug 21, 2017 | Apple Computers & Internet
How do I login in?
Go on your website then click on sign in and enter login id and password then click on login button .
Dec 25, 2014 | Computers & Internet
Login and password
The default login and password should be in your user manual. If you cannot find the manual, check the MFG website or Google your brand and default login. If you cannot access because of your own password and login, reset the router (manual or website should walk you through this) at which point it should reset login and password to default.
Nov 13, 2013 | Computers & Internet
How do I reset the switch?
select restore factory default in administration tab or push reset button
Jan 18, 2011 | 3Com Baseline Switch 2948-SFP Plus 48-Port...
Password recovery steps for lucent dsl max 20 dsl terminator
You have been prompted for the login password and received the following message: “Login Password isinvalid”.• Re-enter the correct password and press enter. Remember that the password is case-sensitive. Check that youare entering admin in lowercase and that the Caps key is not active.• If you have forgotten the password, you must reset the login password. Refer to the User Guide, ChangingConfiguration Switches, and perform the following procedure:1. Move switches 5 and 6 down.2. Type login <newpasswd>. Password checking is overridden.3. Move switches 5 and 6 up.4. Complete any configuration update that caused the prompt for login.5. Change your login password to a new password.6. Store the configuration and reboot the router.Note: If you have not reset switches 5 and 6 to the up position and have rebooted, this will place the router inmaintenance mode. Set switches 5 and 6 up and turn the power off and
www.alliedtelesyneurope.com/media/.../manuals/rg624-34_um_a.pdf
Mar 13, 2010 | Lucent DSL Terminator 100 Router
How do i Reset or break in to get reset my password on 3Com 2948 Baseline Switch 48Port SFP Plus
The resetting of the password requires the installation of a console cable to the console port.
Be sure the terminal emulator program is set to VT-100 management using compatible, 38400 baud rate, no parity, 8 data bits and Console connection one stop bit.
Use the included cable, or be sure that the pin-out complies with a standard null-modem cable
Once the cable is connected, reboot the switch. Type a Ctrl/C until you enter the failsafe mode. This will be denoted with the prompt: “CFE>”
At the prompt execute the following commands:
CFE> passwrd
CFE> reset -sysreset
At this point the password has been reset.
Jan 20, 2010 | 3Com Baseline Switch 2948-SFP Plus 48-Port...
Will not accept login and password.
Duh... when restarting the computer... before it got to the login and password acceptance fields, I hit F2 (setup). I was able to default password settings there!
Mar 23, 2009 | Dell OptiPlex GX260 PC Desktop
Telnet password
Use this step:Router>enable Router#config t Router(config)#line vty 0 4 Router-2(config-line)#login% Login disabled on line 66, until 'password' is set % Login disabled on line 67, until 'password' is set % Login disabled on line 68, until 'password' is set % Login disabled on line 69, until 'password' is set % Login disabled on line 70, until 'password' is set Router-2(config-line)#password newpasword
Mar 08, 2009 | Cisco 800 (CISCO802) Router
I forgot my Password to the Login of my Laptop
Have your HP laptop login password forgotten? Do you have another administrator? Have you created Windows password reset disk on your HP computer when it is available? Or whether you have installation CD?
If you have administrator, just change HP login account to this administrator and access HP computer with it. At this time, no matter which account, you can easily change or remove its password on Control Panel.
If you have password reset disk, on Windows login screen after you type incorrect password, there will be a message "Reset Password" prompting you to reset forgotten Windows password with reset disk. Just follow password reset wizard to do.
If you have installation CD, it will help you to restore HP computer or repair computer. But it is still dangerous for us to use it because it will delete some important data on your computer.
In consideration of data safe on computer, Windows Password Genius provides a safe Windows password reset environment WinPE. With it and in such password recovery environment, you will don't need to worry about data lost or damaged.
This is a video showing how to use it.
http://www.youtube.com/watch?v=quxuEqpG6f4&feature=youtu.be
Jul 11, 2008 | Computers & Internet
3Com Baseline Switch 2948-SFP Plus 48-Port Gigabit (3CBLSG48-US) Logo
1,214 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
