Toshiba Cyclone CX 34862 Television
Hi , My Toshiba 34 inch tube type TV won't turn on it merely clicks on to start and then shuts down immediately and all you can hear is a crackling sound (static). I have tried everything including Hard start-up with no luck.
Can you advise and thankyou in advance
Regard
Gene
    Genius:
  • 1,139 Answers
Hello winman1,
It sounds like your shutdown circuit is shutting down your set. This is done usually because one of the stages in the TV most likley the High Voltage section is drawing excessive current. I would suggest that you take your TV to a qualified repair facility. Since this type of problem is a sign of serious problems.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 24, 2008
Standby light blinks twice approx every 2-3 seconds tv won't turn on
Visit this site 'Electro-help" for details. Type in the site name either to Google or Yahoo search box, and click search. It has all details about tthis fault, and repair.
May 11, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
When you hit the power button you can hear it click and the stand by light begins flashing, but the set wont turn on
Any malfunction associated with an automatic shut down usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 11, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Apr 11, 2009 | Televison & Video
Won't turn on - relay clicks, power supply squeals, relay clicks, etc,
The television has a protection circuit. Sound like you know something about electronics so that is cool.
I suspect the HOT or High Voltage Transformer. If you want to operate on it, they typically will short externally from moisture or plastic high voltage breakdown. The TV starts, shorts as it cannot come to full high voltage, then shuts down. If your brave, you can unsolder the HOT which is the part that is on the main board or that comes from the top of the picture tube wire into a dark or spaceship type object.look underneath, sometimes they short underneath and you can scrap the carbon and get it to at least start up and work. Do not leave this as a fix as it can be a fire hazard.
The HOT is the most common. They are around 20-60 bucks. 34" TV. I am assuming this one without looking it up it is NOT a flat screen, as most do not squeal like that nor do they have to de-gausse like the old ones. I just looked it up and yes it is not a flat screen. Old school, so that is more thank likely the problem.
Mar 02, 2009 | Zenith C34W37 34" TV
Toshiba CX32D60 Problem
Not a tube issue...........It is going into shutdown mode...
1) Pull chassis...solder any /all bad connects in horiz,vert,power
circuits....look for evidence of over-heating....
2)Check for weak electrolytic capacitor in horiz driver circuit..use ESR meter..................................................T.
Dec 25, 2007 | Toshiba 32AF43 32" TV
Toshiba 37 inch tube tv wont turn on
Any set that won;t turn on is probably due to a power supply converter which has burned out switching semiconducors. The first thing to do with a set which will not turn on is to check out all the switching gear (ie switchmode converter circuits) and all associated drive and driver semiconductor devices. Once you've done this you will usually find the problem.
Dec 13, 2007 | Toshiba 32AF43 32" TV
Sony 34 inch Trinitron TV
uplug and open the cover and look for the red cable coming out of the picture tube. follow this red cable to a small board where you should see 2 black screws labled focus and screen. try turning these a notch and power on. it worked for some people but not for me...:(
Sep 23, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
27 inch tube tv won't stay on
You have a problem is in your horizontal section which also is part of your power supply. The high pitched whine is from the Intergrated High voltage transformer (also called the flyback transformer). This sound occurs when the freuency of the transformer changes and or the voltage gets too high. The click occurs as a result of the drawing of excessive current by the HOT Horizontal output transistor. This is repairable, but requires the correct equipment and a schematic.
Sep 19, 2007 | Philips Magnavox 27MS343S 27" TV
Screen flashes green and tv shuts off
The average life of a picture tube now days is only 6 to 7 years,base on the symptom and the age of the set I hate to tell you but your picture tube is bad and it has to be replaced but a new picture tube for this set would cost more than a brand new television,I would suggest not to spend any money and invest in a new set.Sorry
Nov 03, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
Electro Med Services...
