Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw brake has jammed on how can it be reset
Chainsaw brake on my neighbour's Husqvana 41 petrol chainsaw has jammed on. I have taken the coverplate off but there is no means of slackening the sprung band. How do you slacken it off so it can be reasssembled and reset?
    President:
  • 2,220 Answers
Hello David; I think you are saying it is operating normally and is intact but the brake is released and the band will not fit over the clutch drum. If I am correct this latches the band open when the hand guard is attached to the clutch cover.
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
If the hand guard is not attached to the clutch cover try this:
Chainsaw brake has jammed on how can it be reset - 1544957.gif Secure the cover (as above), then use a pair of pliers or a crescent wrench to rotate the spoked portion CW until it latches. It will require some force.
If I misunderstood your question or you need a diagram of the brake parts please reply below.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 25, 2010
Husqvana chainsaw - answer from Tim Doolittle - I am stuck at the stage before the clutch. I can't get the plastic casing off the chainsaw.
If the chain brake is broken it is probably wrappes arond the clutch drum you will need to pry it off with a screw driver and probably have to replace the complete chain brake
Jan 09, 2017 | Garden
How do I remove the clutch cover from a Ryobi chainsaw?
There are two nuts that hold the clutch cover and chain bar in place. The same nuts you would loosen to adjust the chain tension. Once those are taken off the cover, bar and chain can be removed.
Sep 03, 2016 | Ryobi RCS3535CA 14-inch 35cc Petrol...
Hi, I have an Husqvarna 41 chainsaw, it has been brilliant all these years but just recently, for no aparent reason it stopped running when I put it under load. I have stripped it down to clean it and have...
Go to partstree.com type in model no then go to crankcase and you will see fuel tank vent and location
on diagram. Be sure to check your fuel line in tank to make sure it is not broken.
Oct 28, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
Replacement brake band
http://www.husqvarna.com/us/forest
Jun 17, 2010 | Husqvarna Chain Saw 20" Bar
Threads in barrel that hold exaust bolts have been stripped,husqvana 350 chainsaw,would be grateful for advice.
Take it to a local chainsaw seller/mechanic. They will put in a threaded insert (Heli-coil) for less than the price of the tools required for you to do it. Call local saw shops for an estimate. Should be $10±. HTH
Lou
Nov 09, 2009 | Husqvarna Chain Saw 20" Bar
Hushqvarna chainsaw 36/41 brake sidecover where do i get one?
You can find the part number here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
A google search for "Husqvarna YourPartNumber" should provide ample outlets. GL
Lou
Oct 04, 2009 | Garden
Have a Husqvana petrol chainsaw that i ran at the weekend on unleaded petrol (forgot oil additive!) and now it wont start. Have drained out the fuel and now put right mix in (50:1). still wont fire. any...
Your saws piston is probably shot. To check remove the exhaust, to do this remove the retaining bolts and take the exhaust off. remember the order you take off the parts! When the exhaust is removed slowly pull the saw over (with the on off switch off) look at the piston as you do this. If there is any visible scoring the saw is unfortunatly knackered. You can replace the pot and piston but it's usually expensive!!
Sep 21, 2009 | Husqvarna 16 In. Chainsaw Replacement...
Husqvana electric chainsaw
Hi.
maybe its not sharper enough to cut those things that u r trying to cut.
check the saw tooth and use the chainsaw sharpener if u don't know how to make ur chainsaw sharpener take a look on this link.
click here.
i will fix u but you should rate me deal??
Aug 18, 2008 | Electrical Supplies
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
802 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
