Question about Thermador MASTERPIECE ME302EP Stainless Steel Electric Double Oven
Thermador Double Oven - Lower Oven stuck in oven "pause" mode
We just put in the Thermador Double Ovens....the top one works fine but when we go to put on the lower oven, the display immediately goes into a "pause" mode....which cannot be cleared without turning the lower oven off. I'm not sure if it not installed properly and therefore won't work or if there is some other problem. Has anyone seen this situation?
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
  • 113 Answers
SOURCE: Thermador double ovens have a top oven and bottom
it shouldnt matter
Posted on Apr 27, 2009
EllaWatson25
  • 725 Answers
SOURCE: Lower heating elements on double oven will not work
This is most likely your control board is bad. Give us a call with your brand and your model number and we will send the correct part out to you right away! We hope this gets you going before the upcoming holiday season.
Posted on Oct 09, 2009
localwonder
  • 6784 Answers
SOURCE: Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Posted on Dec 08, 2009
AZBen
  • 193 Answers
SOURCE: double oven,the top ovens lower heating eliment
There are some small relays on the circuit board in the area of the controls. These relays are undersized and normally fail shortly after the warranty period. If you are handy with electical work and a soldering iron you can replace the components on the board using standard items from Radio Shack. If not, then buy the circuit board but expect to pay a lot. I once fixed a friend's oven and broiler by putting a low voltage optical semiconductor relay from Radio Shack into the space of each failed mechanical relay. Then I used those to operate large 40A definite purpose contactors -- normally used in HVAC systems. This required addition of a 24vac power transformer. All of it fit easily into the space behind the control panel of her drop-in range. The beauty of the optical semiconductor relays is that they isolated the electrical system of the original circuit board from the additional parts I was supplying. This makes is easy for anyone who works on it later to see the nature of the upgrade/repair.
Posted on Dec 12, 2009
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
What does code F 64 mean for my thermador double oven?
F64 will appear if lower oven air switch does not close. If air
switch does not close the mode is cancelled after about 45 sec-
onds.
Sep 23, 2014 | Thermador SC302T Electric Double Oven
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Nov 27, 2009 | Thermador SC302T Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Jan 30, 2008 | Thermador SC302T Electric Double Oven
Thermador MASTERPIECE ME302EP Stainless Steel Electric Double Oven Logo
329 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
