Question about Dell OptiPlex GX400 (2090246019) PC Desktop
My compuer very slow - Dell OptiPlex GX400 (2090246019) PC Desktop
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 55 Answers
Fix registry errors: cleaning up the Windows registry is usually the most effective solution, because the majority of computer problems are related to the registry.
I would recommend you try this cleaner http://www.keep-pc-clean.com/
Posted on Apr 29, 2010
  • 358 Answers
Sorry about the problem.
I will try as much as possible to give you a detailed steps you can try out.
And they are going to be in two Options.
First options is this:
Put on your Computer,
While it is booting, Keep tapping the F8 Key, and this will bring up the Menu where you will have to
select the different options of booting.
Try booting into safe mode.
If it boots in Safe Mode,then do these:
First, open my computer,
right-click on your hard drive, and select properties,
then select tools tab, then under the tools tab, you should see error-checking,
then click on "Check Now", then select the tabs under this and click on start.
It will tell you that it will be done at the next system restart, so click on OK, and restart your system.
Next, Defragment your hard Drive, by going to Start--->All Programs-->Accessories-->System Tools-->Disk Defragmenter.
All these things are going to take you a lot of time to finish but I'll tell you the truth...they are worth it.
After all these, you can now (optionally) improve the performance of your system by going to this place :
Right-Click on my computer, Properties, then Click on Advanced, then under the performance tab,
click on settings,
and select 'adjust for best performance'.
This will change the appearance of your system and significantly increase your system speed.
If it doesn't boot into Safe mode, then go to this next one:
Select Safe mode Command prompt.
When you get to command prompt, type: chkdsk or chkdsk /f (note the Space before the /f), and press enter.
This will scan your system for errors and correct it.
In case it is as a result of a hardware problem, try this:
Get a screwdriver, unscrew your laptop at the back where you have a symbol of RAM(Memory) drawn,
If you can't do it by yourself let a technician do it for you.
Remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
if the two of them works, them insert the them all.
but if it is just one that worked, just remove the other one that is not working and replace it.
If Trying All these does not work, then Go to this next option.
If you have a Windows Installations CD.
Insert it into your CDROM Drive, then when you put on your system,
Go into the system BIOS/Setup by pressing 'Del' key or any other key (e.g F10 for HP PCs) required to enter setup while the system is booting.
Now look for where you have Boot Sequence or Boot Order.
Select the CDROM to be the one where the system will boot from,
then follow the On-Screen instruction and select repair.
(Which means you will have to get a Windows Installation CD.)
All these are the FULL trouble-shooting steps you will need to get your system working.
But if after trying all of them out it still does not work,
Then you will have to take the system to a good technician.
Kindly keep me posted and let me know how it goes.
Thank you for using FixYa.
Good luck
Posted on Apr 25, 2010
    Guru:
  • 163 Answers
Keep ur system virus free and extend the memory of the system. Remove unwanted Startup programs
How do i get my imvu working fast?
Maybe the computer is fine and perhaps its you that needs to slow down a bit.
Apr 25, 2014 | imvu.com
Ram requirements biostar n6853b
SIR i have bought new AMD pc it config is 3.2 GHz . with biostar n6853b board
  1. problem:-when i on my pc and check the compuer config it shows 833MHz and system is also slow .
May 11, 2012 | Computers & Internet
Im formatted my compuer intel r pentium r 4 after finish download os the graphic is very slow
You're probably saying that the graphics resolution is very low... not very slow. Everything seems too big and a little fuzzy, huh? This is because Windows currently hasn't recognized the correct graphics chip yet. Go online, update the video card driver, and all will be well.
Jul 21, 2011 | Intel ASUS P4SC Socket 478 Pentium 4...
Just bought a Samsung H200 HD camcorder. Works great. Problem is that playback on my HP Pavillion DV7 64bit PC is slow and the image quality and color are poor. I tried different programs and settings. ...
Your computer is to slow. I have the same problem and on faster compuer was good.
I have another problem: I want display films via DLNA form computer to plasma PS50C6500 Samsung and TV say: I haven't code to MP4.
Leszek
Jan 03, 2011 | Samsung H200 Full HD Camcorder
When i open an folder my compuer always ask to
that means your system affected with virus. you can open it by choosing internet explorer from the list. Or you can choose the drive from drop down menu in address bar in my computer.You need to scan your system with anti-virus and remove autorun.inf virus.
Apr 24, 2010 | HP Pavilion dv9623cl Notebook
My compuer became a slow one?
Try Cleaning it out . Run some cleaners suchs as
Adware - http://www.lavasoft.com/
CCleaner - http://www.ccleaner.com/
Eusing Registry cleaner - http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
Those should remove alot of unwanted items and malicious files that you dont want.
another thing is to goto Start ,programs,accessory, system tools , and do a disk cleanup . ... Once a month i do suggest doing a disk defragment and thats in system tools to ..... all other programs i would run weekly !!
Good Luck !!! GD515
Jan 28, 2009 | Computers & Internet
Slow
First thing that you can do to speed up a computer is to make sure your computer is clean from virus, malware, spyware , trojan because they can slow down your system , so first of all use a good anti virus and anti malware software like Malwarebytes to scan your computer and then after that remove some unnecessary program on your compuer to free up some Memory and the last thing to do is to add a RAM to your computer that will really make it fast...
Dec 28, 2008 | Microsoft Windows XP Home Edition
1990 mitsubishi mirage 1.5 automatic.problem is car is stuck on 3rd gear.reverse is fine.but when i first accelarate car is slow moving cuz trans starts in a higher gear
Your car is in failsafe mode. I would definitely have a check at the computer, normally you would smell beuning at the compuer. They are known to have faulty/leaky trnasistors.
Cheerrs
Nov 03, 2008 | Mitsubishi Mirage Cars & Trucks
Compuer doesnt know my camera to download picgt. i need a program so i can
have a fuji finepix a360 and lost my cd and cant install it on my new compuer can you help
Jun 14, 2008 | Fuji FinePix A360 Digital Camera
Dell OptiPlex GX400 (2090246019) PC Desktop Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
