Question about Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Bottem spray bar doesnt spin - Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
  • 229 Answers
Check if it rotates freely if you spin it manually.
If there are no jams. Most likely there is not enough water circulation. Pump or motor is not working properly.
It will need to be removed and rebuilt or replaced.
Posted on Apr 26, 2010
Roller doesnt spin on my dc15
Hi there, it's Jack at Dyson.
If your DC15's brush bar won't rotate, it may need resetting. In order to do this, please follow the steps shown in our Support video:
If you'd like further advice after giving this a try, you can reach our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 10, 2014 | Dyson 909592-05 DC-15 Roller Brush Beater...
Vacuum doesnt pick up very well any more
Larry Kessler:
Unplug the vacuum and lay it down on the floor upside down on some newspaper. Remove the vacuum head foot plate with a Phillips head screwdriver. Remove the beater bar and belt by pulling straight up on the beater bar. Pull the end caps and bearings from the ends of the beater bar... it may take a two-grunt pull to remove them, or CAREFULLY use a screwdriver to pry them off. Remove the hair, carpet fibers and other gunk from the ends of the beater bar, bearings and end caps. Pour (or spray) alcohol on the bearings and spin them until they spin freely. Dry the bearings so there is no alcohol in them.
Put a few drops of light machine oil in the bearings, (3 in 1 oil will do), and spin the bearings to distribute the oil and ensure the bearings spin freely. Now would be a good time to check the vacuum head opening and the hose for clogs. Reassemble the end caps and bearings to the ends of the beater bar and reinstall the beater bar assembly (with a new belt) in the vacuum head. Reinstall the foot plate, and your machine should pick up fuzz balls the size of Michigan!
Feb 15, 2013 | Vacuums
Dishes not cleaned properly
Check the small round filter mesh, make sure its clean and that its not clogged. Use a degreaser on your machine then put it throught a hot wash to rinse it through.
Remove the bottom and top spray bar and inspect the spray holes and make sure they are completly un obstructed. Replace the spray bar and check that they spin freely. If they are not spinning well remove them again and check the mating surfaces for contamination and wear. if they are worn both the spray bay and their respective receptacles will need replacing.
Oct 03, 2012 | Neff 24 in. S5453X1 Built-in Dishwasher
I have a kenmore dishwasher and the spray bar does not spin and the dishes come out dirty.any suggestions what to look for.
Check that the jets at the end of the spray bar are not clogged with food particles etc. That is the most common cause. Also check that the spray bars rotate freely.
Jan 22, 2011 | Kenmore Dishwashers
Bosch Exxcel Diswasher SGS43E08GB/43. Top spray bar won't spin. All arms, spray holes, ducts, filters, etc are clean and free from obstructions. Water comes out of the holes on the top bar but it won't...
try starting the washer, then opening to door and checking the water level in the bottom of the machine, as far as I know, there should be enough water there to disolve the tablet when it sits in the bottom. if not that much, bung in a few cupfulls and you should see the pressure dramatically increase!
Oct 28, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
The middle and top spray bar does not seem to
Is there enough water getting into machine. I it fills until the float shuts off water valve the the pump or motor may be bad.
Jul 10, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
The top cleaning bar will not spin---water is moving through it but it wont spin--the bottom cleaner spins fine---took it apart and there is not blockage in either of the cleaning bars
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
vvbn
Mar 24, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
How do i turn up the sound
loo for a speaker type icon on the bottem right of ur screen and click one time and the bar should be at the bottem hold the  eft button of the mouse on the bar and drag it up and if you dont see it go to start and look in control panel
Feb 14, 2010 | Acer Aspire 5100 Notebook
No sound
Hi I am Vortash sounds like you have corrupt drivers and need to reinstall them .
You don't state what O s you are using so I assume it is either Vista or Xp , look in control panel and see the speaker Icon look at settings and see if there is an audio system presently on there it may tell you your sound card type if you are unaware what type it is .
If it says no device then your drivers have deffinatly not been installed and it may be just running on the generic drivers that are unsuitable for your card . hope this helps and allows you to find your problem .. regards Vortash
Jul 04, 2009 | Toshiba Satellite Pro L300D-EZ1001V...
Whirlpool top load belt driven commercial --spins while agitating
tobe a belt driven wp it would have tobe pretty old,if so its down in the cam bar area.the feet or plungers break and the cam bar dose not pull back.i would remove cam bar and file to clean up or replace if to worn along with new plunger.also use lite greese on cam bar where it slides and on bottem of blungers.also check the condition of your wig wag[control magnet.May God bless your house,tom
Jan 02, 2009 | Whirlpool GSC9455 Top Load Washer
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
121 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
