Toshiba D-VR16SB Gets error code: e4 54037380
Toshiba D-VR16SB Gets error code: ''e4 54037380'' when i insert a Dvd-RW disc, which is the right disc, any help?
  • 687 Answers
This DVD combo will only read DVD-RW and DVD-R format discs the manual says that Verbatim DVD-RW 2X are the best to use also TDK DVD-R
Posted on Nov 08, 2010
  • Latrouche Achraf
    Latrouche Achraf Sep 04, 2014
    Disc incompatibility may be an issue with some disc MIDs. Every disc manufactured has a disc Media Identification Code (MID) that represents the disc manufacturer and the process they use to manufacture the disc. The drive/recorder manufacturer will tune their drives/recorders to the disc MID to allow for the optimum or best recording onto the disc. When newer MIDs become available, after the drive/recorder has been released to the market for sale, the drive/recorder manufacturer will tune to these newer MIDs and release a firmware update for the drive/recorder. These updates will program the drive/recorder to recognize the new MIDs of the discs. The buyer should check the drive/recorder website frequently to stay up to date on firmware to assure the best compatibility with the discs in the market. When a drive/recorder manufacturer has not tuned their drive/recorder to the disc MID the recorder may give an E4 54037380 error which indicates that the disc cannot be recognized by the drive/recorder. The discs may not be defective. It is more likely that the drive/recorder is not tuned to their MID. The buyer of the recorder should check with the recorder manufacturer to assure that the discs they purchased or plan to purchase are tuned to this recorder.
My toshiba dr4su will no longer record on dvd-rw discs nor will it format a blank or prerecorded dvd-rw.Ihave used this recorder successfully for a couple of years. It will play back dvd-rw. When I attempt...
If its an older recorder it could be the usual problem of a greasy center-disc =
95% OF THE TIMES I could fix a problem like this was by cleaning with rubbing alcohol the rubber ring on the little rotating disc in the center of the drive mechanism. !!!! Because users always stick their index finger into the hole of all the CD'S for inserting a disc into the tray that a tiny amount of grease gets deposited onto the little rotation disc which touches the center of any inserted disc at about half an inch from its center hole. (underneath) When its greasy the discs slide and the inserted discs speed stays uneven and slow.
You must open the drivebox ( after unplugging the power-cable) to see and clean it.
Be careful to not look at it with power "on" because the laser will make you go blind (danger!!!!!!!
I heavily use a Toshiba DVD recorder since 12 years and it is my most reliable and most versatile recorder, while my brand new Sony recorder lasted only 2 years - Others as well had problems with finalizing etc. but in general the cleaning of the little center-disc that pushes from underneath against an inserted DVD to make it spin helps the most.
Oct 26, 2011 | Toshiba DR4 DVD Recorder
Can read but can't burn dvd drive in toshiba laptop
IF YOU HAVE WIDOWS VISTA, IT WILL WONT ALLOW TO MAKE COPIES, OR THE DISK YOU ARE BURNING IS RIGHT PROTECTED...IF THESE ARE NOT THE PROBLEMS CHECK YOUR BURNING SOFTWARE SETTINGS...OR LAST THING IS TO CHANGE YOUR DRIVE
Oct 14, 2009 | Sony Toshiba Qosmio F45-AV411 Notebook
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba SD R2312 CD-RW/DVD-ROM
I have the same problem like you.one of the expert shared to me that my burner has faulted. I thing your problem is worse than mine cause I can still read cd rom vcd/ DVD files and movies. Just finfd new one that will give you quality output.
Aug 27, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Insert disc code 011-02-1028
It may be compatibility issues with that certain blank dvd media, dvd drive may not have dvd writing capabilities or drive is faulty.
Feb 20, 2008 | Toshiba (SD-R2412) for Satellite A10, A15,...
Writing to a DVD+RW disc
You need to use DVD software such as Nero that supports DVD-RW. from the app is where you would erase and so on
also make sure your blanks are +RW and not -RW
Jan 10, 2008 | Toshiba Satellite A75-S206 Notebook
Televison & Video Logo
1,139 people viewed this question
Top Televison & Video Experts
Electro Med Services...
