Question about Whirlpool Washing Machines
I have a whirlpool WTW58ESVW washing machine and it will not fill up with wateror run the wash cycle
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 25, 2010
What does LF stand for on a Whirlpool Washing Machine?
LONG FILL....I usually means the faucets are not turned on fully OR you have a pinch in the hose and it is taking too long to fill (LONG FILL).
Jun 02, 2015 | Whirlpool Washing Machines
Washing machine will not turn on
First, check to be sure the door lock is securely fastened and the door is locking. Post back the results.
Jan 20, 2013 | Whirlpool WTW58ESVW Top Load Washer
My whirlpool front load keeps cycling without the water filling.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle runs, drains, but will not fill up for rinse cycle
The water inlet valve solenoid needs to be replaced , they are made together.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Feb 06, 2009 | Whirlpool LSR8433K Top Load Washer
Washing machine will not cycle
I have a Whirlpool Ultimate Care II. My washing machine would not cycle once it filled with water. I purchased a lid switch from partselect.com. The installation took five minutes. This corrected the problem. I hope this helps.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Washing Machines Logo
    99 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
