Question about Toshiba 42H81 42" Rear Projection Television
How do i turn my tv to video?
I am using a toshiba tv and need to turn it to video so i can see to play my xbox
  • 178 Answers
Posted on Apr 25, 2010
Playing bluray through xbox one on toshiba TV
Make sure the display resolution is set correct for your TV,
How to change the display resolution for your TV on your Xbox One...
Also make sure the TV is on and set to the correct HDMI input before using the Blu Ray.
It is also possible the TV does not support HDCP, if not, it will not work with the XBOX one Blu Ray. You may be able to use the Component (Red Green and Blue) cable though.
Apr 07, 2014 | Toshiba Televison & Video
Turned xbox on. tv said "not supported mode". turned off . completely unplugged, re plugged, switched hd/tv switch, no results. what is the problem?
try using a xbox 360 HDMI lead, you can buy one here:
http://www.play.com/Games/Xbox360/4-/12361467/Official-Xbox-360-HDMI-AV-Cable/Product.html?_%24ja=tsid:11518'cat:12361467'prd:12361467
Mar 22, 2011 | Microsoft Xbox 360 Console
Toshiba Theaterwide HD 51h84
It is your projector tub if you are getting alot of blue in the picture. Those guns are very expensive to replace. I am sorry to tell you that. It would be cheaper set from wal-mart for your kids to play on.
Nov 23, 2009 | Toshiba 51H84 51" Rear Projection...
I can not get my TV to change from video to tv
My tv will not display any of its video options. I want to play my xbox 360 but it will not work on any video 1 , 2 , or 3. I also heard that toshiba tv's aren't the best. So I really like to know some tips that can help me fix my tv.
Sep 03, 2009 | Toshiba 36A43 36" TV
My xbox 360 does not display VIDEO buy plays sound perfectly
Check to make sure the video selector switch on the video cable is set to proper position according to your type of tv. (TV or HDTV)
Unplug your cables and then plug them back in again.
You can also turn on your Xbox using the controller. As soon as it turns on hold in the right trigger and press the Y button. This will reset the video system settings.
It may be possible that you have a bad video cable but I doubt it.
If none of the above works you'll need to call xbox support to have your console repaired especially if it's still under warranty. If it's still under warranty, (under 1yr old for this type of problem) Microsoft will repair it for free.
Aug 13, 2009 | Microsoft Xbox 360 Console
No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Mar 26, 2009 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
52 in RCA
The RCA needs a flyback if its an ITC222 chassis which is waht the D52W20 RCA is. You can get a replacement flyback at the following link with free tech support so you can do the repair yourself which is a very easy repair. You need flyback number 259296. As far as the XBOX you should never play any video games on a rear projection TV as it can cause burn in on the CRTs if it is paused. video games are best played on a direct view, plasma or LCD TV. Rear projections like the RCa is not a good idea because of the possible burn in. heres a link to your flyback 259296
http://servicemanuals.vstore.ca/
May 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 42H81 42" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
