Question about Acer Aspire 5315 Notebook
How do I change the settings to get the top symbols onthe keys?
  • 476 Answers
Uninstall the keyboard from device manager
shut down and restart
it will auto reinstall when it restarts
need more help just let me know thanks
Posted on Apr 25, 2010
Hp laptop number keys will not work at top
if hp laptop does not work a the top
1. check the shift key maybe it is working
if it is working
2. go to settings. you will see keyboard setting click on it and access the settings very well
Jul 31, 2014 | HP Computers & Internet
I forgot my network key id
How To Reset Your Router's Password: Resetting a router's usernameand password back to the default username and password. I thought thiswas a great question and worthy of a post. In order to get your routerback to the original settings, you must push in the reset button (usually onthe back of the router) for somewhere between 10 and 30 seconds depending onthe router. You may need a pin or something small to push in the button,because it can be recessed. Once you have reset the router, the usernameand password will be changed to the defaults, admin and password,respectively. One thing you must rememberis that resetting the router will change all of the router settings back to thefactory settings. This means you will lose all of the changes you madesince you got the router. Make sure to write down any things you'vechanged, so you can change them back after the reset. Also, I recommendupdating to the latest firmware after the reset.
Sep 20, 2011 | Computers & Internet
I dont know how to access all of the symbols that are on a key e.g. one key has a question mark, a slash and two other symbols, one is blue and the other is green
You use teh shift key and the [FN] key to access these extra sets of characters. If it is basically a circle around a symbol then press and Hold the [FN] key while pressing the key you want. If it is the ?,,{,},:," or any of the symbols on the upper part of the number keys at the top of the keyboard just press and hold the shift key while pressing the key.
Jul 24, 2011 | Computers & Internet
The euro symbol is under the 5, how do i type this?
The keyboard shortcut for the € symbol is Alt Gr + 5. However if this does not work, you may also enter the following key combination : Alt+0128.
You have to maintain the Alt key pressed while entering the 0128 code.
Hope this helps you.
Jun 01, 2011 | Acer Computers & Internet
I need to know how to use the number symbol key on the brothers typewriter em530. It has two symbols above the number 3 key a / and # I want the # sign. When I press the shift and press number 3 it gives...
On brothers there is usually words written above the top row of keys. One of them usually says KBII
Press CODE and that key and you will select the second set of symbols.
DickyO
May 11, 2011 | Brother EM-530 Typewriter
HOW DO I TURN ON THE RADIO FOR WIRELESS CONNECTION ON THE LAPTOP ASUS501
The wireless switch is usually located either on the front or side panel. It might be a slide switch. Take a better look at it. Or else check if you have an antenna looking symbol onthe top of the key "F2"...If so, press Fn + F2. That would turn it ON..
Dec 04, 2010 | Belkin Computers & Internet
I have HP Compaq nc6220, but Every time I want to insert the @ symbol I have to press "Shift & the 2 button". The symbol above the 2 key shows is " But if I press the key that has the...
You will need to goto the control panel goto reginal setting and set to your country, then goto the language tab at the top goto details, adjust this at the top using the small arrow to bring down the other choices set this to england united kingdom click apply then ok and exit out of all open windows now check your keyboard, if still the same reboot the computer then try hopfully your keyboard will be as you want it. hope this helps and post back if you have dificulties.
Oct 27, 2010 | HP Compaq nc6220 Notebook
I get the wrong symbol when typing on my new dell
Hold-down the ALT GR ("alternate graphic") key, to the right of the space-bar, and press the '2' key, release the ALT GR key, and you should get '@'.
Jan 23, 2010 | Dell 0Y3740 Keyboard
Trying to change the intercom caller ID onthe M7324
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Oct 23, 2009 | NorStar Meridian M7310 Phone
Acer Aspire 5315 Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
