Question about Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer DVR111d drive
Hi I have just upgraded my Apple Mac iBook G4, 933Mhz, to os x 10.5.2. My DVR11d keeps throwing a paddy and I get error messages when I try to burn dvds. Is there a driver/firmware that I need to install to use this drive?
    Genius:
  • 3,587 Answers
Most likely...go to the os 10 site, and look around. or you may need to try the pioneer website, find your drive, and check for o/s compatibility
Posted on Mar 23, 2008
6ya staff
SOURCE:
I need to upgrade my iBook G4 OS X 10.4 to 10.5
You would need a PowerPC G4 867MHz or faster processor and 512MB of RAM in order to do that. You will also need to find a copy of OS X 10.5 from a 3rd party as Apple no longer sells the OS installation disc.
Aug 30, 2013 | Apple MAC OS X 10.5 Server Unlimited...
Apple logo and loading symbol
If you have another MAC computer available, you can create a USB key to solve this problem:
http://www.techrepublic.com/blog/apple-in-the-enterprise/how-to-create-a-bootable-usb-to-install-os-x/
If not, I'm afraid you will have to turn to an authorized apple service center. They will do the repair for you.
Jul 19, 2013 | Apple iBook Laptop G4 iBook 1.33GHz...
Can I upgrade the operating system on the g3?
OS X 10.3 supports your machine... you may have problems if your hard drive is too small.... It looks like this OS will work with your G3 IF you have ample hard drive and memory..
Jan 17, 2010 | Apple iBook G3 Clamshell (M2453B) Mac...
On start-up, (from HD or CD) I get the Apple, then "unable to fin
This is the message you see when a version of OS X has been installed on a Mac that needs a later version of OS X at minimum, or when the custom gray install disc for one model of Mac has been used to initialize another model of Mac.
You posted this under "iBook G4," and the platform in the error messages says "PowerBook." Provided you posted in the right place, that confirms the above diagnosis.
Initialize your iBook with the proper gray disc, or a retail OS X installation disc, and it will operate properly.
Nov 13, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
I was trying to install Mac OS X 10.3 on my G3 iBook, it did not work, and now neither does the iBook.
It sounds like you have a hardware issue of some sort - likely a bad hard drive, due to age. I would suggest taking the laptop to a repair shop (don't bother with the Apple Store, they'll tell you to buy a new laptop or just turn you away). Best of luck!
Nov 09, 2009 | Apple iBook G3 Mac Notebook
Powerbook G4 titanium
Insert your Mac OS disc, restart your computer while holding down the C key. This will launch your computer on the disc system instead of your hard drive.
From the menu select Disk Utilities.
Repair permissions and repair hard drive in your computer..
Restart... you should be back up and running.
K
Jun 21, 2009 | Apple iBook G4 Mac Notebook
Apple iBooke Blueberry power problem
It is a system problem. There is only really one way to fix this.
You'll need to start your mac up from the original OS install disk.
You can then use the disk utility to see if the OS can be fixed or you might need to re-install the OS. Once you have started up from the install disk you might be able to see your drive. At this stage if you have not already done so you should back up those important files.
Aug 10, 2008 | Apple iBook Blueberry Mac Notebook
Cant load os
Hi Tajjek,
Try booitng the Mac from the installation disc which was shipped with the machine,make sure to use the right disc( which was shipped with the machine). If the unit does not boots to the OS disc,then remove the internal hard drive and power on the machine if you get flashing question mark after start up boot chimme then it is issue with the internal hard drive. Please get backt to me with your observation if issue persists.
Feb 13, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
When we try to open dreamweaver it quits
It sounds like some components maybe missing or the application is corrupted. Try going into:
Hard drive/Applcations/Utilities/Disk Utility
You should see your hard drive on the left pane, select the volume under it, which usually is what youve named the drive or MACINTOSH HD if it hasn't been renamed. Select FIRST AID, then below select repair disk permissions. Restart the computer and try relaunching. If oyu still get the same "Unexpected quit" message, see if it gives you an error message code. If after you repair the permissions on your hard drive you still get the error, I'd uninstall and reinstall the OS, upgrade your OS X to the current 10.4.10...if the issue still occurs, your hard drive maybe failing.
Hope this helps.
Oct 20, 2007 | Apple iBook Mac Notebook
Pioneer DVR-112D DVD RW Dual Layer Burner Logo
191 people viewed this question
Top Pioneer Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
