Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Machine does not fill with water
On starting any cycle, following the tablet droping, the nachine does not fill with water. The cycle goes through as nornam without water. Cosequently the dishes do not get washed! hi iv just installed idl 40 an cant get it to work wright my lights come on an flash an it sounds as if its trying to pump water in but its not can any one help me .....
  • alwysbarbara Jul 02, 2008
    machine not emptying
  • Anonymous Nov 03, 2008
    first light flashes but no water comes into the 20 month old machione
Thank you everyone, i had the same problem and this worked a treat. gave the thing a dam good jiggly and its now going thought the cycle perfectly well.
Thank the lord for google from which all things are possible!
Posted on Jul 05, 2008
Thanks Maidstoned
We did what you suggested, and although there was no indication of a leaky nut or pipe, just tipping it on its side and back again seemed to fix it!!! We think the pipe had an airbubble. Its what my mother used to call the hit-the-engine-with-your-highheel technique.
Thanks loads of dishes!!!
Droz
Posted on Jun 28, 2008
  • 4 Answers
Pull the unit out and tip it carefully to one side. (put some rag down first to mop up the water) then stand the unit back up.
Make sure you can see the back of the unit. put some tissue paper behind the plastic pipe that runs up the back centre of the machine. Turn the unit on and put into cycle. after a few minutes carefully remove the paper if its wet (even a little) the chances are the star shaped lock nut inside is loose or the pipe is damaged. A replacement is readily available and should cost less than a tenner to buy. just make sure you order a new seal as well and get a 20-25mm jubilee clip to replace the one installed. Failing that check the water pressure to the unit!
Posted on Apr 24, 2008
I have just got my idl 40 and cant get it to work either. flashing lights, sounds like water is trying to go through but nothing...dont' know why, phoning engineer tomorrow.
Posted on Apr 12, 2008
2 Suggested Answers
SOURCE:
silly girl
  • 513 Answers
SOURCE: Machine does not fill with water
I had a Zanussi d/w up until about 5 years ago and there were two perennial problems that required attention. First of all, there was a double solenoid inlet valve for the water supply at the back, one part was the main fill, the other was a supply to the water softener - big plastic lump in the bottom under the salt filler. The main fill solenoid would fail about every 2 years and I would buy a replacement directly from Zanussi for about £10. I believe the failure may have been due to the fact that the machine was filled from the hot supply. This was allowed in the specification but the higher temperature may have led to failure. (Side note) In any case, it is better to fill dishwashers with cold water anyway because during the initial part of the wash cycle proteins are rinsed off rather than being stuck on the items, and secondly, heating from cold increases the contact time of the wash detergent solution and also improves results. If the solenoid controlling the supply to the water softener has failed, it may well lead to the phenomenon you are seeing because the regeneration cycle happens after the wash in most machines. If you feel comfortable about using a mains tester(a neon screwdriver one would do) and can *safely* reach the solenoid with power on and the machine the right way up, then you could see whether power is reaching the regeneration side of the valve or not. If it is, and water is not entering then you have the culprit. Another area that affects filling is the level switch. Generally these are pneumatically operated device looking like a flat drum, about 8cm across and 1cm or so thick. They are generally mounted up high in the machine or door and have two or three wires on terminals and a small flexible plastic tube leading somewhere into the wet area of the machine. As the water level rises, water goes part way up the tube and air above it operates the switch to turn off the water. Sometimes there are two levels used and hence two switches inside this assembly working at different pressures. One could have gone. Another problem is that gunk can get in the lower part of the tube and reduce or block it from detecting. and generally this results in no filling at all. Hope this helps!
Posted on Mar 26, 2006
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Washer completes cycle 100% but then it restarts and starts filling all over again/ rewashes in essence
Dear William, I guess first you have to check if the start switch is shorted. When you turn on the machine, does it automatically go into cycle? If yes, then your start switch is faulty. Otherwise, you may have to replace your timer/sequencer.
Jan 16, 2014 | Washing Machines
How do I clean coffeemaker?
All you need to do is purchase des calling tablets/powder/liquid and run it through your machine. It goes in your water compartment. Some machines have a cycle on them so use that. After running the cleaning solution make sure you fill up the water tank at least three times and run the clean water through your machine.
Sep 16, 2013 | Coffee Makers & Espresso Machines
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Asko Frontload wont stop running water
    you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
    Mar 17, 2008 | Asko W6441 Front Load Washer
    Mar 25, 2006 | Zanussi 24 in. DA6141 Built-in Dishwasher
    Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
    370 people viewed this question
    Top Indesit Dishwashers Experts
    Eric Taylor
    Marvin
    Marvin
    Paul Bade
    Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
