Akai 4000s Wind Synth
When swithching on the EWI, nothing works, I only get two small zeros in the program/display window.
Can anyone help?
Steve
I have a Akai 4000s Wind Synth which has been great up till now, today it stopped working for some reason? When I switch it on I can't get any sound, the only thing showing on the program/display is 00 (2 small zeros like the top half of 88) Please help!!!
Steve
  • s7t7e7v7e Mar 24, 2008
    I have traced the problem to the Line Out/Phones jack, when either of these is used the Wind Synth freezes and won't work!
    Any more thoughts?
    Scholar:
  • 105 Answers
This is a common fault - faulty capacitors in the power supply section need replacement. Low and noisy voltage rails are stopping the Akai initialising properly.
Please rate the assistance given - this should enable you to fix the problem.
Posted on Mar 23, 2008
Ewi 4000s cutting off
My EWI 4000s started to play by its self making a loud low note and then it stop and now it won't play at all. I Reset to Factory Preset but that didn't help. What do I need to do to get it to play again?
Feb 09, 2014 | Akai Ewi4000s Electronic Wind Instrument
Ewi and vocoder setup
hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder?
Mike Phillips is the same, or if it only works with the EWI 4000s?
and as a connection is made?
thank you!
Feb 04, 2013 | Akai Ewi4000s Electronic Wind Instrument
Program change on the akai 4000s
Please try to wet your fingers a little bit.
When your fingers are dry the ewi would not react properly.
Jun 15, 2009 | Akai Ewi4000s Electronic Wind Instrument
My akai ewi 4000s kind of froze
Please try to reset the ewi. You can do this like this: Shut down ewi. Press down the four little white buttons Level, FX, Setup and Trans. Keep them pressed while starting up the ewi.
This is a factory reset.
I hope this works for you.
Apr 03, 2009 | Akai Ewi4000s Electronic Wind Instrument
Articulation problem after firmware 2.4 update
Hi is the mouthpiece clean-easy to take off & wash-is the air pipe clogged up?-have you tried adjusting key sensitivity--I have 2.4 and no problems but the key sens. needs adjusting quite often--temperature-humidy-etc..seem to screw it up for me---have you tried reloading the patches with the editor--I use Patchman patches and they work great
good luck Shanti
Jan 21, 2009 | Akai Ewi4000s Electronic Wind Instrument
EWI won't respond to comands
I've got the solution.
Turn the EWI off.
Press the LEVEL, FX, SETUP and TRANS buttons all together.
Turn on the EWI.
This is a Reset to Factory Preset.
Greetings Fred Roubos.
Dec 13, 2008 | Akai Ewi4000s Electronic Wind Instrument
Detuning of Akai EWI 4000s
Are you shure that you aren't touching the bend up plate with your right thumb? This isn't easy detected by sax players which are used to have a thumb rest at exactly the same spot where the bend up plate is. You might switch it off (see manual). With the bend up plate on you should aways use a tight strap which helps a bit to not touch the bend up plate accidentally. I'm still struggling with this occasionally.
Oct 31, 2008 | Akai Ewi4000s Electronic Wind Instrument
215 people viewed this question
 Grubhead
Grubhead
