Question about Logitech QuickCam Messenger Web Camera
Screen is not clear?...what are the procedure or steps to store it clearly?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Good day. Just try to clean the glass front of the camera.
Posted on Apr 25, 2010
Can't connect to wireless network error code 104
Hello Friend
Follow these steps:
Step 1: Clear the cache stored in your Google Play Store App by going to device Settings >Applications > Google Play Store > Clear Cache and also Clear Data.
Step 2: Open Play Store and sign-in using your Google account.
For any help or support just visit us: Roku Com Link
Jan 12, 2013 | Roku HD Streaming Player
How to unlock it if you forget the password?
This is for MID7015
Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the MID7015******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Jul 07, 2011 | Coby Kyros 716829701508 Tablet PC
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
I have a H3 error code on a xerox workcentre Pro 215. What do I do to clear it?
This should correct it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Dec 15, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Error mesage
IF these steps do not work you will have to replace the fuser or fuser heat rod then perform the reset.
May 15, 2008 | Xerox WorkCentre Pro 16fx Laser Printer
Trouble code
May 06, 2008 | Sharp AR-160 Copier
SHARP AR-M277
this should resolve it.
Jan 22, 2008 | Sharp AL-1655CS Laser Printer
Black screen
If one of these solutions doesnt work you will most likely need to purchase a new calculator.
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 12, 2008 | Texas Instruments TI-83 Plus Calculator
How to clear all information from screen
screen has (m3)and (m1) in upper left corner, have not been able to totally clear screen.
Apr 10, 2007 | Texas Instruments TI-30XA Calculator
Logitech QuickCam Messenger Web Camera Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
