Question about Intel X25e Kingston Ssdnow E Series 32gb Sata 25in Internal Ssd KINGSTON 32 GB SATA Hard Drive
My USB Drive has been not open in my computer
  • 358 Answers
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Or in case there is a problem with the read/write head inside the hard drive.
What I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Apr 25, 2010
How to Remove Shortcut Virus on Windows?
Connect the affected USB drive to your computer. When the files on your USB drive have been changed to shortcuts, your files are actually still there in a hidden location. This process will restore the files so that you can see them again.
  • Do not run any of the shortcuts on the USB drive, or you risk spreading the infection.
Determine the drive letter of the USB drive. You'll need to know the drive letter for the USB drive or memory card that has been affected by the virus. The quickest way to find this is to open the "Computer"/"This PC" window. The drive letter for the USB drive will be listed next to the drive label.
  • Press Win+E to open the window on any version of Windows.
  • Click the Folder button in your taskbar to open the window.
  • Click "Computer" in the Start menu if you're using Windows 7 or Vista.
Open the Command Prompt. You'll be performing the fix using a few quick Command Prompt commands. The process for opening the Command Prompt varies depending on the version of Windows you are using:
  • Any version - Press Win+R and type "cmd" to launch the Command Prompt.
  • Windows 8 and newer - Right-click the Windows button and select "Command Prompt."
  • Windows 7 and older - Open the Start menu and select "Command Prompt."
Type .attrib -h -r -s /s /d X:\*.*and press? Enter. Replace Xwith your USB drive's letter. For example, if your USB drive's letter is E, typeattrib -h -r -s /s /d E:\*.* and press ? Enter.[1]
  • This will unhide the files, remove any read-only attributes, and remove the shortcuts.
  • The process may take a while to complete, depending on how much data is on the USB drive.
Open the unnamed folder created on your USB drive. This folder will contain all of the data that was previously hidden by the infection.
26319209-bxzhjmonsmllydp0qa2riq2g-2-20.jpg Copy the recovered data to a safe location on your computer. This is a temporary location while you finish cleaning the drive. You can create a folder on your desktop to hold the files for now. Just drag the files from your USB drive to whichever folder you choose.
  • It may take a while to copy large amounts of data.
Right-click on your drive in "Computer"/"This PC" and select "Format." This will open the Format window.
  • The formatting process will completely erase the drive, so make sure that you've copied your data off of it first.
Uncheck "Quick Format" and click "Start." Unchecking "Quick Format" will scan for and remove the infection on the USB drive. The format process will likely take a while to complete. 26319209-bxzhjmonsmllydp0qa2riq2g-2-44.jpg
Oct 20, 2016 | Microsoft Computers & Internet
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you transfer files from the computer to usb?
Right click the file you want to copy and select "Copy". Open My Computer and double click your USB, then paste the file you copied
Mar 15, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Cannot open thumbdrive, Requesting us to chose the a program to open the thumbdrive programs.
try using another computer to open the thumb drive. is the computer USB 2.0 compatible ?
Nov 03, 2010 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
I just bought a PNY 4 GB High speed usb 2.0 drive I would like to put my pictures on it how do I do it? from my computer.
Insert the USB drive into any USB port of your computer. When you do, you should see a window pop up that asks what you would like to do now. Click the option to browse the files. You should now have a window open for your USB drive. Next, open up my computer and find your pictures on your hard drive. Once you have found them, you can click and drag the pictures from the hard drive window to the USB drive window. Do this as necessary for any or all the pictures.
Nov 19, 2009 | Computers & Internet
Computer crashed while USB was inserted. USB will no longer open.
Scan you pendrive for Virus from another computer who has effective antivirus program & it have latest Update.
Norton is my trusted.
Thanks.
Oct 06, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
I have a PNY 4GB high speed USB Drive. I want to
Well, the easy way would be to do this
But if you want to use the USB drive just insert it into an open USB port
  1. click Start
  2. click My Computer
  3. Select the USB drive from the list of connected drives
  4. Click and drag the files from their location to the USB drive
To get them to the other computer follow steps 1-3, then click and drag them from the USB drive to their new location.
Sep 16, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How do I download from my computer to Iomega Hard Drive
Hi I am Vortash if the hard drive you are downloading to is in a usb carrier , then all you have to do is drag the files you want to an open window for the hard drive you are down loading to .. example ..
Connect external Hard Drive to USB .
wait for computer to recognise drive .
when the window comes up on how to open drive select the files option and the drives window will open .
select My computer .
select C:\ from my computer
Click click on the files youwant and drag to the open external drive window .
This will then copy all files you have moved to your external drive ..
To copy the whole of your drive just drag C:\ to the external window and all files will be downloaded ... hope this helps regards Vortash
Jul 13, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
My USB flashdrive cannot be opened
have you tried it on a different usb port? if that doesnt work you may also try it on a computer
Jul 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My 2gb kingston usb flash drive cannot open / read to any compute
There are several USB recovery programs available. While I don't endorse any one in particular, I tend to stay away from "free" ones, since I believe in the axiom "there's no such thing as a free lunch" since you don't know what's in it for them.
You could try this company, which advertises a free download (but I suspect they are really a shareware company so it's possible that they will want money for a more expansive version) which may make it possible to fix your drive in one instance at least.
If this data is important to you, it's probably worth spending 30 or 40 dollars to avoid a repeat.in the future, because USB drives get corrupted from time to time.
Anyway, here is the link:
www.premiumdatarecovery.com/
Good Luck and If you find my assistance valuable, please give me a rating.
Jan 22, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Intel X25e Kingston Ssdnow E Series 32gb Sata 25in Internal Ssd  KINGSTON  32 GB SATA Hard Drive Logo
77 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
