Question about Fuji FinePix A345 Digital Camera
How to get rid of a protected card on a fujifilm 2gb camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Apr 26, 2010
FUJIFILM FinePix JX500 digital camera says memory card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 20, 2013 | Fujifilm FinePix JX500 14MP,5x Optical...
Write protected
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 31, 2012 | FUJIFILM Cameras
My camera says memory card protected how do i get it off
Apr 16, 2012 | Fujifilm Slim Camera Case for Fujifilm...
I get the message 'protected card' Next trick?
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 10, 2011 | FUJIFILM HS20 EXR Digital Camera
Hi my camera model is fujifilm a235 now its show protected card error
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 19, 2011 | FUJIFILM Finepix A235 Digital Camera
Camera is saying protected card got a 2gb inside
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 12, 2011 | FUJIFILM A170 Digital Camera
I have a fujifilm 12.0 megapixel camera .it has a fujifilm 2gb memory card and it keeps saying protected card, could you tell me why its doing this
The card is most likely an SD card which has a lock on the side of it to protect pictures from deletion sometimes this switch gets pushed in the wrong direction. I'm including a "generic" picture/diagram of this switch.
Also you will need to format the memory card before it will work properly and be totally compatible with the camera you will need to look in your camera manual for this information. You didn't give me the model of the camera or I would have been able to direct your to the correct page. Once the memory card has been formatted everything should work just fine.
Dec 31, 2010 | Photography
What does "protected card" mean? I have a 2GB Kodak memory card in my Fujifilm/12.2 camera. Lost manuel. Thanks.
It means that the card has been write protected thru the menu program in the camera. To fix this, you will have to go thru the menu and set it to unprotected.
Obtaining a manual for this camera is as simple as going to the Fuji website and downloading the manual in PDF format to your computer.
Aug 02, 2010 | Fuji Photography
My SD card (FujiFilm - 2GB) has decided to make itself 'write-protected' after I transfered all of the photos to my pc & then deleted them from the card. Now it wont let me use it in my camera like it...
SD (and SDHC) cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 17, 2010 | Fuji Rod Repair Kit
I have a fujifilm finepix z30 says protected card.
The SD card has on a side a little switch. Turn in to the other position and it should work fine.
Apr 09, 2010 | FUJIFILM FinePix Z300 Digital Camera
Fuji FinePix A345 Digital Camera Logo
69 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
