Question about Saniflo & Saniplus& Macerator Pump
Toilet bowl, and pump housing are full, drain pipe clear? pump not running correctly. how do i drain it to get acsess to pump?
Prepare to get dirty. Use a mug with a handle to lift the water out of the toilet bowl into a bucket. Reduce the water level until it stops increasing from the backflow from the Saniflo. Disconnect the electrical connections (isolate the unit first) Disconnect the outflow pipe but be prepared for some spillage from any vertical pipe in your domestic installation. Ease the boot off the WC soil pipe, Disconnect any breathers. Slide the unit out from behind the toilet but maintaining a backward tipping angle to prevent water inside the unit from spilling out of the boot. Take the whole unit outside, keeping it tipped backwards. Take the lid off, noting how the seal is oriented for reassembly. Use a high pressure garden hose to clean out the interior and inspect. Check the rubber diaphragm on the bottom of the sensor unit. These develop corrugations and become slack over time. If so it will have insufficient power to depress and release the microswitch within the sensor unit. If your unit filled the toilet bowl with soiled water and the pump kept running, it is likely that the non-return valve beneath the outlet pipe is faulty. On some models the valve is Y shaped and the branch of the Y is a rolling ball that falls by gravity when the pump switches off. Replace the valve. If your unit kept running but with clean water in the bowl, it is likely your diaphragm is faulty. Check for corrugations and make sure it is no longer caked with accumulated solid waste. If you cannot buy a new sensor unit complete with diaphragm, you may need a new Saniflo. Both of my Saniflo units stopped working satisfactorily after 10 years. My German built unit has now been working without fault for 19 years.
Posted on Apr 30, 2010
New basement gerber toilet with sewage pump sys. won't clear bowl, acts like a clogged toilet. Drains dwn eventually
Check the pump operation, to see if it is running slow or otherwise clogged up as it will cause this, if you have freezing weather that to can stop the pump from operating correctly.
Dec 05, 2016 | Home
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
Toilet bowl will not refill
It is possible that the vent pipe behind the toilet is clogged (or was not installed properly). Some bathrooms are set up with one shared vent pipe, and a clog in one of the lines leading to it can cause similar problems.
The vent pipe in each bathroom does 2 things:
1: it lets the sewer gas go past the bathroom and up out the roof so you don't get sewer gas in the house.
2: It breaks the siphon as water goes from fixtures down to the big sewer pipes in the house. If it isn't working for a sink, it's not much of a problem because air gets mixed in with the water as it does down the sink, and this breaks the siphon. But in a toilet, it jsut keeps pulling water down the pipe until the water level in the toilet gets low enough to let air into the pipe, breaking the siphon.
It's not an easy problem to fix and often involves removing walls to get at pipes.
A plumber can bring a snake tool and try clearing the pipes from below or from the roof, and might even be able to bring a steerable snake that lets him control how it goes through the pipe.
Apr 19, 2014 | Kohler Home
Tank empties on flush but bowl doesn't empty. eventually only water very slowly empties from bowl. Brand new
Unless there is some packing material or protective film that you failed to remove it is more likely to be a problem with your home drainage system than the toilet itself.
It could be debris from removal of the previous toilet, a wad of toilet paper or other stuff partly blocking a pipe.
Before doing anything else get outside and open up the man-hole covers. Throw a bucket full of water down and see how quickly it drains away. - if it runs well then the problem is likely to be a blockage somewhere between the toilet and the drain cover.
I would suggest uninstalling the toilet bowl to make access easier then rodding it through with drain rods - you can usually hire these quite cheaply but they are only about £15 - £20 to buy a set in the UK.
Feb 23, 2011 | Kohler K-3489-RA-96 Biscuit Cimarron...
Sanipro xr is less than 6 months old been working fine but has recently become rather noisy. Sometimes goes off in the middle of the night for no reason.
Water pressure makes the unit kick on and off. Somehow water is draining back into the pump casing, check the flapper on the check valve inside the discharge elbow, it may not be closing properly or may be obstructed allowing waste water to drain back into the pump. Also check the flapper on the flush valve inside the toilet tank (water closet) the flapper may be leaking water into the bowl and from the bowl into the pump casing sitting behind. As far as making a loud noise, there could be a blockage on the drain pipe, blade or impeller. The discharge pipe may be loose, not clamped against the wall and is rattling against the wall when in use.
Jan 08, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Our Kohler K3402 suddenly stopped flushing. When you pull the handle and the flapper comes up, all that happens is the tank begins draining into the bowl and the bowl level rises, almost to the rim. The...
If there is a shower in the same bath is it also draining slowly?
If so check that drain systems air vent, (on the roof).
Find the pipe coming out of the roof nearest the bathroom with the problem and when a second person flushes the toilet you should be able to feel
air moving in and out of the pipe with your hand covering the end. If not the vent could be blocked by leaves or animals etc., this vent has to be clear in order for water to drain properly.
May 20, 2010 | Home
Saniplus pump runs and pumps a cup of water and
unlikely to be a vent problem - more likely a semi blocked 22mm outlet - hence the problem with the old unit & the new one. Tricky to solve as 22mm pipe runs are too small for conventional pipe cleaners. Some plumbers use compressed air to clear, others us pressured water (jetter) unfortunately it always ends up a bit messy.
Feb 13, 2010 | Saniflo 002/003/005 Saniplus Toilet with...
This was just installed. When it is flushed the
If there is a air emiten valve on vent ? Remove it than try to see if it works properly. If this works you will need pipe vent outside
Dec 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Standard toilet will not flush
If this is a new development, then you have a partially clogged drain or maybe a crack in the bowl assembly. If the toilet always did this, then perhaps the drain pipe was not installed correctly.
I would remove the toilet and run a snake through to the main stack. If you find that is clear, check the bowl for cracks and check the tank water level to be sure that the tank is filling to the water line on the tank
May 09, 2009 | American Standard Colony 2388.012.222...
Saniflo & Saniplus& Macerator Pump  Logo
574 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
