Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
IMy McCulloch 18
My McCulloch 18" 38cc chainsaw has no spark - I changed the spark plug but still no spark.
  • 2,841 Answers
The coil may be defective.
Posted on Apr 25, 2010
I have a McCulloch 2618 cav chain saw and the chain adjusting screw has broken. How do i replace it.
[PDF]IPL, McCulloch, Mac 2618 CAV, 952802079, 2008-05, Chain Saw www.mcculloch.com/ddoc/MCCI/MCCI2008.../MCCI2008_AAaa__545014313.pdf
  1. Cached
  2. Similar
CHAIN SAW MODEL(s). 545014313. Mac2618CAV. DATE. 3/04/08. Replaces. PARTS LIST. 545014313 -- 5/31/07. Ref. Part No. Description. Ref. Part No.
McCulloch MAC2618CAV - Chainsaws
www.mcculloch.com > McCulloch International > X-ref > Chainsaws > McCulloch
  1. Cached
  2. Similar
Newsroom · Parts & Accessories · Chainsaw parts & ... MAC2618CAV. Select model, 006 · 050 · 10 ... McCulloch MAC2618CAV ' Bar Length - 18 inch/45cm ...
McCulloch MAC 2618 CAV (952802079) Chainsaw Spares & Parts ...
www.ransomspares.co.uk > Parts > Garden Spares > Chainsaws > McCulloch
  1. Cached
  2. Similar
Buy genuine replacement McCulloch Chainsaw MAC 2618 CAV (952802079) spares from an authorised supplier. Price match promise and next day delivery.
McCulloch Chainsaw Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/chainsawpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch chainsaw model below to find OEM part numbers. ... McCulloch MAC 2618CAV Chainsaw Type 1 and 2
McCulloch Trimmer Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/trimmerpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch trimmer model below to find OEM part numbers.
Mac 2618CAV - McCulloch Spares, Parts & Accessories
www.4mcculloch.co.uk > Chainsaws McCulloch Mac 2618CAV SGO002 Spark Plug. Genuine spare part. Suitable for: McCulloch Mac 2618CAV. Type: SGO002 Commonly used in small handheld ...
McCulloch Mac 2618CAV Chainsaws Chain ' BuySpares
https://www.buyspares.co.uk > Chainsaw > McCulloch > Mac 2618CAV
  1. Cached
Buy your McCulloch Mac 2618CAV chainsaw Chain at BuySpares - choose from an extensive range of McCulloch chainsaw parts and McCulloch accessories. McCulloch 2618 Google Search
Nov 29, 2016 | McCulloch Garden
How do I change spark plug in my chainsaw
find where spark plug wire is connected to plug and disconnect very gently, remove spark plug with proper 13/16 or 5/8 wrench or socket and replace with new spark plug
Sep 16, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Can not start mcculloch 540e chainsaw
check for spark if you have spark remove the muffler and try it if it runs good open the muffler and clean the screen inside
Sep 03, 2012 | Garden
How doesw one change the spark plug?
1. Push STOP switch down.
2. Remove air cleaner cover.
3. Disconnect the wire connector (G) from the spark plug
(H) by pulling and twisting at the same time (Figure 7-
5A).
4. Remove spark plug with spark plug socket wrench.
DO NOT USE ANY OTHER TOOL.
5. Check electrode gaps with wire feeler gauge and set
gaps to .025" (.635mm) if necessary.
6. Reinstall a new spark plug.
Here is the manuel with pictures as well:
http://pdfservicemanual.com/home-appliance/2006-2008-mcculloch-mcc1435a-mcc1635a-mcc1635ak-mcc1435a-ca-mcc1635a-ca-mcc1635ak-chainsaw-owners-service-manual.pdf
May 03, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to test magnito on McCulloch 310 chainsaw
The only way to test an ignition module on any small engine is on the machine. Simple and easy.First remove the spark plug , then remove the wire that connects the module to the kill switch, its located right next to the plug wire above the laminations. Put a spark tester in the pkug boot and ground the other end. Pull the rope and look for a spark. Its that simple. If you have a spark, check the switch and wire, if you dont,check the grounding screws that hold the module to the block for a clean contact.If you still have no good spark its time to replace the Ignition module (coil).If you dont have a spark tester, ask someone dumb enough to hold it. If they jump and cuss you out you know you have a good spark
Nov 15, 2009 | McCulloch Garden
Fr2.0 14'' McCulloch chainsaw has no spark when holding spark plug wire while pulling the cord.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If you really sure there is no spark turn on the ignition, put your pinky finger in place of the plug, and give a short pull. If you didn't get shocked the coil, switch, or wiring is bad.
You can find an IPL for your saw here:
http://www.mcculloch.biz/
The model you provided does not cross. A number on your saw will match something. Your coil part number can be found there. HTH
Lou
Oct 15, 2009 | McCulloch Garden
How do you change the spark plug wire?
you have to take the coil out since it is connected to the wire and replace all of it. let me knwo if you have more questions
May 25, 2009 | McCulloch 10" Electric Pole / Chain Saw
Need to know the correct levels of oils in a chainsaw
Most McCulloch saws use a 40:1 oil ratio if using McCulloch branded 2-stroke oil. They state 20:1 for other oils, but this is probably overkill as most name branded 2-stroke oils these days are pretty good. I would probably go for a 30:1 or 35:1 mix to err on the side of caution. This will not affect performance, it may just mean you need to change spark plugs a little earlier than usual, but the cylinders will at least be well lubricated.
Please rate my response on FixYa.
Mar 24, 2009 | McCulloch Garden
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
346 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
