Question about Boating
I have a 1981 evinrude 140hp. it wont shut off with the key.
  • 3 Answers
Check for any corroded or broken grounds leading off of the solenoid.
Posted on Apr 28, 2010
1981 evinrude outboard motor starves for fuel when under load. How to fix
Does it have a fuel filter on it? If so change it if not add one. How old are fuel lines? If they are 1981 rubber lines they may be collapsing under load.
Sep 23, 2017 | Boating
I have a 1981 johnson 75hp charger. blew powerhead so i bought an evinrude powerhead that was omc identical. I have no spark. wiring issues.Thought johnson and evinrude was same wiring?
go google and type in --wiring schematics for johnson outboard motor 75 hp 1981 model --- and see if there is a pdf version for down load
repeat the search but change the name to evinrude and look for a pdf version down load
go to a dealer service center and see if you can get a schematics for each from them
while it can be expected that the wiring should be the same as each brand is made in a different factory there could be a slight difference in the wiring set up that is causing the problem
Aug 09, 2016 | Boating
What should the compression be on a 1983 evinrude 140hp
Compression on an engine is not a good indicator of problems. With that in mind as long as all cylinders are close to each other and 110 to 140 lbs you should be good.
Oct 17, 2015 | Boating
1996 Evinrude 140hp started but ran only for about 10mins.
try removing the feed pipe off the fuel pump to the carbs and start the engine , put a pipe on the pump into a container and see if its pumping ! ?
Apr 19, 2015 | Evinrude / Johnson 135-150-175-200 HP...
1996 140hp evinrude started but stalled. will not restart
Has it been sitting up all winter? If so, you might need to drain fuel from the carb and replace the filter. It sounds like a fuel problem to me.
Apr 19, 2015 | Cars & Trucks
Hi have a 1984 evinrude 35 hp model no E35RLCRR that wont start
There should be two hot wires one from the battery and one from the switch the one from the switch check should be hot when the key is held on the start if it is the starter solenoid is bad
Dec 23, 2014 | Clymer EvinrudeJohnson Outboard Shop...
1981 evinrude wont start i've changed power pack, starter, silanoide, plugs, it will start when i take the battery off and put it on my truck for a min. after that it will start everytime til the next day...
sounds like you charging system might have dumped .or your battery is going bad . check the voltage before hooking it to your truck next time . automatic bilge pumps running drain a weak one really fast
Apr 18, 2010 | Boating
Boating Logo
89 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
