Question about Dell Dimension 2400 PC Desktop
Trying to remove a computer cover from a DELL computer. There was only one screw at the back on the left side. But it is still not opening
Turn the computer around. On the back right side, look for an L shaped plastic piece sticking out. Slide it down. Now, while holding this piece down, sprawl your right hand against the panel side on your right and pull the panel toward the back. (It is often hard to get much of a grip.) It does slide out, though.
Posted on Apr 26, 2010
    Sergeant:
    Champion:
  • 305 Answers
Unscrew and then pull towards back.
sometimes these panels can be very very tight.
hope this helps.
Posted on Apr 25, 2010
How do I remover the cover?
A) You post the model number of the Dell computer.
This is found probably right around that Power On button, but I can't see it clearly in this video.
Look at the Back of the computer.
Post back in a Comment.
B) If I were guessing it would be Dell Dimension 2300, or
Dimension 2350,
http://www.adverts.ie/desktops/dell-dimension-2300-printer-and-wireless-keyboard/2078459
If this holds to be true the Left Side Panel removes.
Looking at the Front of the computer, is how left; and right are determined.
Thumbscrew is approximately 3 inches down, from the left rear top corner.
Thumbscrew is loosened all the way. Isn't supposed to remove, but sometimes they do. (Small clip on screw comes off)
Once Thumbscrew is loosened all the way, pull back on the Side Panel.
There is a molded fingerpull in the left Side Panel, at the back.
If memory serves there are Tabs with a hooked end, that protrude from the Top edge of the Side Panel, and Bottom edge of the Side Panel.
Think of them like a J.
They protrude through slots in the metal framework, of the computer case.
Do to the hooked end the Side Panel only slides so far back, then stops. This is because the hooked end, is stopped in the slot/s.
Push the Side Panel just a little Forward, (Towards front of computer), then pull Side Panel straight out.
Lay aside.
Also FOLLOW Anti-Static Procedures before reaching inside your computer. Failure to do so will result in an expensive conversation piece.
"Yeah, I forgot to follow Anti-Static Procedures, and Static shocked the hardware components inside.
I think it looks good with those plants on it, don't you?"
Your body carries Static electricity.
(You can develop over 75,000 volts, and that may be a low estimate)
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
May I ask what the problem is?
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
4 beeps but won't come on
4 beeps of equal lenght suggest that system timer is not working, you need to change cmos battery on your laptop. If you are game, that is how you change CMOS battery on your laptop:
1. Switch off computer, remove power cord and battery, turn computer "proper" side up, open and press power button to discharge
2. Open display in full (180 degree), there is small indent on hinge cover, close to hinge on right and left side, slide in little flat (screwdriver will do) and lift right side up, slide cover towards left and remove it, do not lift on both sides simultaneously!
3. Remove two small screws on the top of keyboard, lift keyboard slightly up and towards you, be aware that keys and tabs on keyboard are fragile and difficult to replace! Lift keyboard connector and slide the cable out. it is not really necessary to remove keyboard, but it easy to replace without keyboard being in the way.
4. Find coin battery, disconnect cable from socket by pulling it gently towards the battery. Remove cable from guides and battery from it's seat
5. Replace battery with exact same type, put it back into it's seat, guide wire through and connect it back to the board.
6. Re-connect keyboard cable, place front keyboard tabs into palm rest and screw back two back holding screws
7. slide in left side of hinge cover into place, press from left to right till it click in place.
8. Re-install battery and power cord, switch on computer, re-programe BIOS ito previous state.
This should solve your CMOS batery problem. Of course you can send your laptop to the technician but that will be no fun at all... ;-)
Aug 07, 2010 | Dell Inspiron B130 Notebook
Dell 1600n printer, how can I clean the platen glass?
you will need to take your printer plastics off to clean.4 screws on back panel take out then one screw on left side cover.take out paper tray open toner door 4 screws to remove,turn on side and on bottom there are 3 tabs both sides to remove side panels.one side has a speaker wire to unplug.take off display cover 3 screws to take out.lift off top cover and remove 4 screws 2 each side lift off platen and clean. reverse the order to put back together.take your time and be careful good luck
Mar 11, 2010 | Dell 1600n All-In-One Laser Printer
Need to open the Dell Inspiron 530 in order to clean it
Facing the computer your left side is the left side of the computer.
Going around to the back of the computer, there are two screws to remove, so that you can slide the left panel off.
They are along the outside edge of the left panel, and on the backside of the computer.
One is located approximately 3 inches down from the top.
One is located approximately three inches up from the bottom.
In-between the two screws is a bulge. A formed place in the back edge of the left panel.
Once the two screws are removed, hold onto the computer with one hand, and place the fingers of your other hand into that 'bulge'.
Pull back to slide the panel towards the rear of the computer, then lift the panel up, and out.
This Dell Support, and the Owners Manual for the Inspiron 530 desktop computer,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In this main menu scroll down to Removing and Installing Parts, and click on it.
Now on Removing the Computer Cover
Feb 28, 2010 | Dell Computers & Internet
Cover removal
On the back of the system case are an green knobb, puch it downwards and the HDD lid on the right side pops open.
Push it upwards and the left side panel opens up.
Regards
HobbyData
Feb 10, 2010 | Dell OptiPlex SX270 PC Desktop
How do i remove the cover of a Gateway MFATXPNT NMZ 500SE
I found this:
"Facing front of computer you need to remove the left side cover. cover release is on top of the computer in center of side panel. Press in on button and p[ull top of side cover away."
Don't know if it's useful. If not let me know and I'll keep looking.
Mar 16, 2009 | Gateway Computers & Internet
Dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Feed problems dell 5100cn
Did you replace the two paper feed rollers? The paper feed rollers are located on the inside front of the paper tray cavity. you can see them by removing the paper tray, then peering inside the cavity.
As far as the actual question on how to remove the side covers on this unit, you must first remove the top cover frame.
Top Cover Frame removal
  • remove all toner cartridges
  • press the front latch, and then rotate open the inner duplex assembly.
  • rotate open the imaging drum cover.
  • remove the two screws securing the top cover frame to the chassis. ( be very careful not to drop any screws, as they will fall deep inside the frame. I suggest using a magnetic tip screwdriver.
  • press in the 2 tabs securing the back of the top cover frame. ( use a small flathead screwdriver to insert through the two slots located behind where the black toner normally sits.
  • rotate the imaging drum cover open slightly, and then pull the top cover frame up and back to remove it from the chassis.
Right side cover removal
  • remove the screw securing the right side cover to the chassis. ( this is located at the right rear, inside the side cover near the black toner. again use care not to drop the screw.)
  • press the tab securing the front of the right side cover, and then rotate the cover away from the chassis.
  • remove the cover.
Left side cover removal
  • remove the screw securing the left side cover to the chassis. ( this is located at the left rear, inside the side cover near the black toner. again use care not to drop the screw.)
  • press the tab securing the front of the cover to the chassis
  • lift the cover upward slightly, and then away from the chassis to remove it.
Good luck.
PS. please take a moment to rate the solution.
Thanks
Oct 03, 2008 | Dell 5100cn Laser Printer
Dell Dimension 2400 PC Desktop Logo
55 people viewed this question
Alun Cox
