Cant partition, format maxtor drive
Try to partition and format maxtor drive, get error message failed to write to sector 63 of disc, also failed to read from sector 107. tried to partition but so far unable. Tried different methods but no luck. what software will help correct this problem. drive has not been used.
help
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos May 11, 2010
    What is your operating system, can you boot dos 6.0 from diskette ,what is the volume of maxtor,....
    Genius:
  • 1,665 Answers
Connect drive to be formatted as slave.
to check if your windows sees the drive and is it active go to your desktop and right click on my computer -> manage -> Disk management.
You should see something like the picture below:
Your first disk will be Disk0 and 2nd disk will be Disk1 If you cant see Disk1 then the drive is faulty OR not connected properly make sure the drive is working with cables attached.
Listen if the drive spins.
If it doesnt then something is wrong.
If you can see the drive there then you might not have made any partitions onto it. You can make new paritions to the disk right there, right click on your disk1(your 2nd hdd) and create a new partition.
Posted on Apr 09, 2008
    Genius:
  • 1,913 Answers
Hi
try disk manger software or dos comand FDISK to format all partition and then delete it
Posted on Mar 23, 2008
    Novelist:
    Scholar:
  • 117 Answers
If that's a brand new drive, I'd send it straight back for replacement. That shouldn't happen. Sure, you can probably use a utility to try recovering it - but that will probably result in "sparing", the drive using spare tracks at the far end of the disc to replace the faulty one, slowly it down tremendously. And that assumes it can actually "spare" track 0 which I doubt :{
My Maxtor Athena 20GB hard disk is in error
delete the entire partition and do a quick format....
then do partition according to your requirement and try formatting...
if it still says error, then use any disk formatting utility like partition magic and try one more time....
still problem then you should take it back for replacement if it comes under warranty period....
Apr 20, 2010 | Maxtor Hard Drive
When i want format my it reach a place and
Probably you have a defective hard drive. Scan it's surface with acronis partition expert. If it finds a bunch of defective sectors, replace the drive. If it finds some bad sectors, backup your data and replace or use it and risk losing data.
Oct 28, 2009 | Computers & Internet
My maxtor 6 L100P0 is unreadable can anyone help
First you should go to Maxtor's support site and download their diagnostics tools or use an all in one utility disc such as Hiren's BootCD. Almost any of the other utility discs out there should contain all the testing tools you could need, but I like Hiren's.
After you have ran the diagnostics tools and determined that the drive has not failed you will then want to low level format the drive. MAKE SURE YOU HAVE BACKED UP OR RECOVERED ANY DATA ON THIS DRIVE !!!FIRST!!!. Once you low level format your drive the data will be gone for good. The tool to low level format the drive can be found on Maxtor's support site or on a good util disc like Hiren's. What low level formatting does is write 0's to every sector of the driver returning it to factory condition. After this is done it *SHOULD* format correct if the drive is not damaged. Keep in mind if the drive has corrupted once or fails the Maxtor tests it will fail again and it is only a matter of time. I would recommend trying to RMA it only storing data you do not mind losing.
Aug 22, 2009 | Maxtor Hard Drive
CANT DETECT HARD DRIVE
may be your harddrive has bed sectors but u can fix bed sector.
U have to first delete all partition and create new partrtion then
format alll partition.
Jun 05, 2009 | Computers & Internet
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Maxtor 3 one touch mini 60GB won't load or Format
Try deleting All Partitions & then Partition whole Drive,using 59.0Gb.This should give approx. 8MB buffer.
Also when formatting,remember to format Ordinary not Quick Format
Jan 21, 2008 | Computers & Internet
Can't format or create partition......
It maybe that your motherboard bios cannot support 250GB and needs an update, but caution applies here. The other problem maybe that you need to use the hardrive on the 'CS' (Cable select setting). Lastly if you already have a pc running, use this drive as the slave the go to the Maxtor website to make use of the diagnostic/formatting and partition tools.
Feb 27, 2007 | Maxtor MaXLine Plus II 250 GB Hard Drive
you can try an FDISK form a windows boot disk, but you may need to read up a little on how to use it. or maxtor has a program available on their web sit called powermax that can try to find & repair possible problems. powermax may be the best & easiest way to go. good luck.
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
