Question about Philips 32MF605W Television
I have the same issue with my MAGNAVOX 32MF605W/17 when i turn the power on it flashes white then goes black and the amber standby light remains on.... you decribed it as a Mainboard Problem... my issue is finding one online.... No place ive found has a pic or decribes it as the mainboard.. no i seem to talk to can even give me a straight answer as to the part number i should be looking for....
I had the same problem caused by a power surge. Removed the back cover (kind of a pain in the *** because it's a tight fit) then removed the metal cover over the circuit boards. There were three 1000uf 35vdc capacitors on the Left board capacitors 2074, 2079 and 2080, that had bulged out tops. Replaced those with the same capacitor from radioshack (p/n: 272-1032 stock at most radioshacks)for $3 and the tv works fine. During this I also noted that the plug right next to the power switch down by the face was loose, pressed that in and everything is kosher...good luck
Posted on Sep 18, 2010
TURN TV OFF WITHP OWER BUTTON. THENTURN ON WITH REMOTE. MINE DOES SAME THING. ALWAYS USE REMOTE TO POWER ON AND OFF
Posted on Jul 18, 2010
My tv powers off as soon as it is turned on, any ideas?
This is an issue that happens with some of the older firmware versions for this tv. You need to check your current firmware in the menue/features. Then go to the philips website and download the current firmware and follow the company instructions for installation via usb.
Mar 23, 2013 | Philips Televison & Video
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
I have a Magnavox 15MF605T 17 that when the power button is pushed it goes green for a couple of seconds then turns amber. No picture, sound, etc. I unplugged the TV for about 10 minutes and when I...
Try to turn it on with a remote if one is available. If you don't have the original remote you can look up the universal code for the cable or satellite remote. Also try to turn it on with the input source(vcr,video game, cable box,etc...) on first. I have the same TV and if it has no signal prior to manual power up it will go to standby mode.
Jul 08, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Sep 26, 2009 | Philips 32MF605W Television
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
Screen says attention no signal
Your TV is probably on the PC mode and you are not using it as a PC monitor.
You need to change the source by pressing the TV/Video button on the remote control or the SOURCE button on the TV itself. You may also just press the channel up or down buttons. Do this before the TV goes to standby mode (amber light) or while it shows the message: ATTENTION NO SIGNAL.
If it does not work, reboot the TV first and do this again.
May 17, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Philips/Magnavox 32MF605W/17 32" LCD Wide Screen HDTV ready w/ATSC.
Yes you can. This TV has both VGA-In and component in support. The only thing you need to change is the input you're using with your remote control. As easy as changing the channel!
Oct 15, 2007 | Philips Computers & Internet
Power goes green then back to standby
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Dec 29, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Philips 32MF605W Television Logo
1,006 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
