Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Convergence problem/ i saw a tech. go to another screen on the tv to repair this before. can anyone help me to get that screen/
    Problem Solver:
  • 4 Answers
To enter the service menu.
1. Changing the input to an unused input (i.e. Ant B). Turn off the set and wait for the fan to turn off.
2. Hold input and power buttons on set down simultaneously. When service menu appears, release both buttons (input button first).
Note any settings before you change them. I haven't challenged it but I have read online in the forums that entering the service menu may void your warranty. Service manuals are available online at ebay.
Posted on May 10, 2008
The red coler has started to curve about a third of the way down the screen. everything on the the screen is distorted and doubled in red
if your picture looks 3d it is convergence problem.
This is a do it yourself repair if you have some skill.
I will tell you what you need and have start to finish, step by step instructions for this repair along with photos, and source for parts needed(parts cost will be under 30 dollars).
reply here if I can help.
SD TECH
Oct 24, 2010 | Mitsubishi WS-55807 TV
Hit by litning
my friend it is the tv tunner that needs to be replace you will have to take your set to a repair shop for repairs.tv needs qualified tech to repair them.you might cause injury to your self.although you want to save money it is best to have a tech deal with your tv,than doing more damage to your tv and to yourself.it will cost you less on the longer run.good luck
Jun 19, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Screen appears to be bent at the top and bottom.
Ur convergence it dead.U know how to solders?Buy a convergence kit use what in that kit.Tries these Websites for parts.Tv repair World.com,Tvrepairkits. Tv shop will cost u $300.Repair by tv tech.
Dec 16, 2009 | Philips 60P8341 60" Rear Projection...
How do I get into the tech convergance of my
Here are my own instructions----WHATEVER YOU DO DO NOT ATTEMPT TO ADJUST THE GREEN!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Toshiba entry to adjust
With the set on press MUTE on the remote.
Then press and HOLD mute for several seconds and while still holding it on the remote press Menu on the front of the set.
A (S) should appear in the upper right corner of the screen. (It means you are in the Service mode)
Press menu again on the front of the set
7 on the remote will call up the convergence grid
3 on the remote will change the color to adjust from red to green to blue(do not adjust GREEN)
You navigate the grid with 2, 4, 6, and 8 buttons.
To stop the cursor from blinking so you can adjust at any point use the 5 button—to move again use the 5 button.
When you finish you exit by hitting 7 on the remote again.
Sometimes you have to try a few times to get into the menu—I have had my problems but once in it is easy.
Let me know if this information was helpful and if you have ANY questions or need advice let me know.
SD TECH
Sep 25, 2009 | Toshiba TN55X81 55" Rear Projection...
I'm having a problem with my Toshiba 57H81 Rear Projection TV where there is to much green in the picture. Adjusting the tint and colors only helps some. I notice when I turn the TV off rather than a ...
Two things---first if you don't mind give me a vote here--I am rated on how many problems I fix
Second---with the original remote go into the customer menu and select Convergence---see if you can adjust the other problem that way---I can if that helps you email you the instructions for going to the tech menu to adjust convergence all over the screen and and saving those adjustments----if you find the convergence will NOT adjust in some area of the screen you may have a convergence problem.
I would appreciate a vote here for my help and if you need the directions for the advanced convergence let me have your email.
REGARDS, SD TECH
Sep 20, 2009 | Toshiba 57H81 57" Rear Projection...
50 inch hitachi tv, shadow behind writing and crooked screen
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hutachi 43inch rear projection 5 yrs old
Hitachi Convergence
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
The repair for a Hitachi requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Some models don't have a separate convergence board and the board is not usually available for the ones that do have a separate convergence board. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
If you change the original ICs with substitute "new and improved" parts that are talked about in the blogs, you will probably create problems. Use the original ICs and resistors.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Jul 30, 2008 | Samsung HCN4226W 42" Rear Projection...
RCA P52937SG Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Shadows on Rear Projection TV
Sony Convergence
Jan 25, 2008 | Televison & Video
Picture warping
Yes this is a typical convergence problem, and there are two convergence Amp Ic's that are in need of replacing. If you have any solid state repair experience, you may be able to replace these IC's yourself, but if you do not have any solid state printed circuit board experience, play it safe and call in a tech to assist you in this repair.
Jul 14, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
105 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
