Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
Western Digitial 320 GB Passport - Unable to access files
I am unable to access the files in my WD 320 GB Passport drive. It does not get listed under My computer. But I am able to view it when i select safely remove hardware option. The LED in the harddrive keeps flickering but i am not able to access the files.
I tried other USB's and they are working fine. Pls helps as I have lot of valuable and close to the heart data in it.
  • 358 Answers
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Or in case there is a problem with the read/write head inside the hard drive.
What I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Apr 25, 2010
Permission reset
Login with Administrator account on Windows (Root account on Linux) connect the WD passport, access the files / change the permissions.
Nov 14, 2013 | Western Digital Computers & Internet
Tip
Western Digitial Passport Sync Software
WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a backup drive; it is NOT !
As per the documentation with this device:
"synchronization software is intended to synchronize the data from a computer to the drive (WD Passport) and SHOULD NOT be used as backup software. To use this software properly, we advise that you do not wipe or
erase the data from the internal hard drive (computer) and resynchronize, as this will cause the data that WD Sync stored to the Passport to be deleted."
This is why you are hearing so many people saying that they are deleting the WD Sync software, reformatting, and using the WC Passport as a true backup drive where you can actually see the files that you are backing up, rather
than a bunch of unrecognizable sync files that likely don't have all the files that you thought you "backed up".
on Jan 18, 2009 | Western Digital Passport WDXML800UE...
Wd passport
Not all DVD-players support DivX encoding of movies.
Check that your DVD-player does support DivX.
Dec 31, 2009 | Western Digital My Book Essential Edition...
Wd passport can't see the writing on the icons in setup
Try hitting enter, Windows should automatically recognize it as an external drive and install driver.
click on "my computer" and the new drive should be there.
Jun 19, 2009 | Western Digital WD Passport 250GB Portable...
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
Ibm t43, xp pro won't recognize my WD 320 passport
Well, that IBM is from 2004, the usb port and drivers is to old for the WD 320 who requries USB 2.0. Thats why your IBM dosent recognize it, your IBM getting wrong signal from the WD thrue the old usb port.
I dont think you gona make those items to work properly togher M8, sorry
Nic
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
WD3200ME-01 Passport size diskspace problem
To format the drive to allow files larger then 4GB: Open up My Computer, Right click on the Western Digital Drive. Select Format from the list. Under file System, select NTFS. Under format options Check Quick Format. Click Start to format.
Warning! Formatting will delete all data and files on the drive. Make sure to transfer all your files to another drive before preforming a format!
Jul 03, 2008 | Western Digital 320GB MyBook External USB...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
369 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
