Question about Samsung LA37A450 37 in. HD-Ready LCD TV
I have a Samsung LCD Tv, model LA37A450. Whenever i press the volume up on the remote the tv turns off automatically. If i do the volume up on the tv itself it works fine. It only happens when i use the remote and only that one button on the remote. The tv had been working fine up until this point.
  • t_muirson Apr 26, 2010
    Also i should add that i have recently programmed my panasonic dvd recorder remote to control my tv because of the problems i was having, and that remote control works the tv completely fine. It's only when i switch back to using the samsung remote and the volume button
    Yeah i was wondering if it's a problem with the remote or programming with the remote or something as the panasonic remote has no issues at all
    Thanks
REPLACE THE IR BOARD AND FONCTION BOARD SOMTIMES THEY COME TOGETHER SOMETIMES SEPERATE
Posted on Apr 26, 2010
  • Anonymous Apr 26, 2010
    ANOTHER POSSIBILTY BORROW ANOTHER SAMSUNG REMOTE IF SAME PROBLEM REPLACE SUGGESTED BOARDS
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Need an activation code for my sky+ remote to operate the volume on my samsung lcd tv le40s8.
switch to sky on tv and press interactive on sky remote then move down to sky customer service (select) once screen has loaded move down to programe your remote you will need model number and make of tv press select and then enter the make of tv by moving down list once found select and repeat for model then follow on screen instructions
Dec 11, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
I just connected a new Samsung LED/LCD TV. I am
programm the remote to your tv by pressing the TV button till all lights light up at the top then enter your 3 digit tv code ( samsung codes are 738, 516 or 680 then press pound. this should enable you to controll power and volume, be sure to press sat to operate you dish recvr.
Oct 07, 2009 | DISH Network Televison & Video
Picture has multicolours and is like a colour
Picture has moving multicolours and is like a colour ngative on the samsung digital tv. Model la37a450c1
Aug 14, 2009 | Samsung LA37A450 37 in. HD-Ready LCD TV
Closed Captioning comes on every time i turn on the tv!
Apparently the 2002 Sharp model TV that I purchased has the closed captioning by default if the mute button is engaged. So there is no solution for my particular model, it has been built in this way. The only solution is not to use the mute button and lower the volume instead.
Jan 03, 2009 | Televison & Video
Sky remote
TV
RED + SELECT
TV
0056
press the volume button if it works press SELECT to save if not press TV again then volume repeat this step until the volume works remember to press the SELECT button to save the code.
Cheers
Little Dish Fitter
Dec 27, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Samsung 37
It sounds like your TV is set at Shop Mode. To veify that turn on your TV and press the info button on your remote, some info will be displayed, If Shop Mode appear please follow the next steps...
In order to change that mode turn on your tv, press the volume key (either one) on your front or side panel (Depends of the model you have) the volume bar will appear, once this happend press the menu key on the front or side panel and hold it for like 7 seconds, "Dynamic" symbol will appear at your screen this means that you are not longer at Shop mode. You can double check by pressing info button at your remote
Regards
Jan 14, 2008 | Samsung LN-T4665F 46 in. LCD Television
Samsung LA37A450 37 in. HD-Ready LCD TV Logo
422 people viewed this question
Henry  Thomas
Henry Thomas
