Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Internet connection setting for Belkin N wirelss modem router
On expert installed my modem and it use ok until I format my PC and installed windows xp again. The modem is working fine but I don't see the plinking icon on the system tray. Do I need to make setup for UAE or any other setting up.
Please help
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
If you can connect to the internet without the connection icon in the system tray, I think its fine. But if you really want to see the blinking icon, go to start>control panel>netweok and internet connection>network connection. There you can see the local area network icon. Right click on it and then properties. A new window will appear, make sure the "show icon in notification area when connected" is checked. Thank you and good day.
Posted on Apr 25, 2010
Installation of belkin router failed
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
May 08, 2010 | Belkin (F5D5231-4) Router
I have lost my install cd for my belkin g wirelss router f5d7234-4 what cn i do
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 28, 2010 | Belkin (F5D7230-4) Router (587009)
Connection problems
Hi
In the back panel of the router we have four ports together and one by itself
the one byitself if for your internet connection from ur modem and connect ur coputer to any of the four port.
gud luck
thanx and regards
sukhvinder
Jul 27, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin n wirelss router setup
I made a video on how to do it on my F9K1003V1. It should be close to the same setup. The IP address you use to log into it should be the same as I use in the video but the menu will probably be a little different.
Feb 14, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless modem router
Where are you actually putting your ip and dns numbers? I need to check if your actually
connected to your belkin router, so on your computer we need to launch your command prompt
if your using windows. Can you brief me on what system your using there?
thanks
Sep 26, 2008 | Belkin (F5D7231UK4) Wireless Router
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless Modem Router problem
well, first of all the i also have the N1 belkin wireless modem router, in order for it to connect, there has to be a wireless connection in your area for you to connect to, if any of your neighbors so have wireless you can connect to their network, but if you are not getting a conection that means no one around you has wireless or lan, the belkin wireless is not a internet provider it just extends the distance of your internal wireless. some networks may be secured as well, sometimes you can only connect to unsecured networks unless you have the name and passcode for the secured network.
May 28, 2008 | Computers & Internet
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Router and configuration settings for DSL wireless setup
Maybe you should use same brand of your adapter, use belkin wireless router.
Most of the router has a manual attachment, it will teach you how to configure the router..
Nov 16, 2007 | Computers & Internet
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
141 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
