Back to:
Tags:
JVC HD-52Z575 52 in. Rear Projection HDTV-Ready Television
No picture.
posted by Karlenglund on Mar 23, 2008
Hello, I have had my JVC HD-52z575 for about 3 years. It had performed perfectly. About a year ago I got the message to replace the bulb. I did not replace an reset my timer because picture was fine. Last night when we sat down to watch a movie the picture went out. Well I thought my bulb went out, no problem can't gripe about that service. We didn't turn off the set but were on PC looking for a bulb to order when the picture came back on!! It lasted about10 min and went back off. This is the state I am in now. I can turn off and wait a couple hours and turn on, no picture. If I leave it on it will come on in about 15 minuites and last 5 to 15 min and go dark again. Any idea's??
Thanks
Karl
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 11, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The lamp is turned on by a high voltage ballast, very similar to the ones in your fluorsecent light fixtures. Your ballast is starting to fail. You should have your TV serviced by a JVC authorized service center because they have the training to deal with this issue. Waiting until it fails could very likely cause more servere damage especially if it fails shorted then the power supply will need to be replaced as well.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No picture.:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
JVC HD-52Z575 52 in. Rear Projection...
hi i have installed a new lamp original jvc but still have...
Dear Sirs: The color is uneven with a two foot diameter...
Lost my manual and could use help. TV brightness is...
i had a power surge..now there is no power..what do i do?
Please help....only blues and greens. :(
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
