Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
How do I get the USB input into the monitor channel on a Behringer Xenyx1832usb
  • Behringer Master
  • 5,603 Answers
I suspect that you don't, at least easily.
Try this:
IF you can send it to the mains, run a cable from the mains 1/4 jack back to an unused channel input. Set the monitor level on that channel to send the mains back out to the monitor so that anything on the mains from USB will be in the monitors... This is hokey and you have to disable this channel by not sending it to the mains, from the mains lest the thing will oscillate.
As versatile as this Behringer stuff is, I rather doubt that the USB can be routed directely by setting to the monitors... But just ry to find documentation about this!
Typical of this brand, finding and understanding the documentation can be frustrating.
Posted on Apr 27, 2010
HOW DO I HOOK UP PASSIVE MONITORS TO BEHRINGER PMP4000
If you are using the amp in stereo mode, then you will require a separate amp for the monitors and the input of that amp are taken using BALANCED TRS cables from the monitor jacks. If you are using the amp as MONO and monitor, then connect NO MORE than two 8 ohm speakers to the Speakon plug on the back labeled for use as monitor. Refer to your user manual... they have detailed photos of the connections. If you lost your manual, you can download another from the Behringer site. There are settings you need to do to configure the unit after connecting your speakers. The small slide switch has to be set to the center position for Main/Mon. Make sure it is centered as many people have had it slightlyu off and the system will NOT pass audio. You need to set each channel "monitor 1" level control to send the monitor signal to the MONITOR mixing bus. You will then use the MONITOR 1 slider to control the amount sent to the monitor. Be VERY careful of grounding the sleeve of 1/4 inch jacks that originate at the Speakon power amp outputs as the SLEEVE of channel A is the HOT side and you can blow the power amp for the channel... it is EXPENSIVE to repair.
Sep 30, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I have a Behringer sx2442fx mixer,and when i try to use my aux 1 and 2 channels for monitors it doesn't seem to be working. I sthere a chance that i have a button or something on the board thtas p
Make sure that you have enable the main monitor volume at the end of the mixer. They are labeled AUX1 and AUX2 as well located under the last channel of the mixer. If those are on 0 your monitors won't work
Jan 19, 2012 | Behringer Sx2442fx Eurodesk 24channel...
I have a Behringer PMP 6000 that I just bought. With the power amp switch in Main L/Main R it works fine, but if I switch it to Main/Mon, only the Mon works, nothing from the Main. Bridge mode doesn't...
Bridge mode you use chan B (left connector on the back) using a SPECIALLY wired Speakon. The impedance of a speaker connected as such CANNOT be LESS than 8 ohms.
In the Main/Mon mode, the two amplifiers are separated in function. The monitor knobs for EACH channel input control the mix sent to Channel A which is for the monitor speakers. The Mon1 controls the level sent to Output A for the monitor speakers. Mon2 fader is NOT used.
The individual channel faders control the main mix and the Main fader controls the level sent to Output B which goes to the main speakers.
Apr 02, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
HI, My behringer 32 channel eurodesk mixer's some of the channels not working. No sound for the mike input. Please help. I am in phoenix, where can i take this?
Has somebody spilled liquid into the unit? Are you using XLR to XLR mic cables? If using condenser mics you need Phantom power on else NOT.
If the faders are noisy, use CRC226 in them. You can get that at Home Depot in the electrical dept.
NEVER use contact cleaner such as Deox.it or BlueShower in faders... it wrecks them
Feb 28, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
My macbook pro will not identify the usb mixer. it said the mixer would work with a mac or pc, so what can i do to make them compatible?
hello, I have a behringer 1832. the issue I have is that the right channel is out all together. both subs work. it is only the right main. do these things have some sort of mono switch that I don't know about?
Nov 21, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
I'm using garageband and for some reason it won't record on my computer all the time it has worked previously , but i can't get it to record in the moniter input
It is not clear what your configuration is. The monitor OUTPUTS are monaural. For recording you should be using the MAINS OUTPUTS and those NEED to use the the MAIN1 IF you are using TRS balanced lines, else if you record with unbalanced cables you need to use the MAIN2 outputs...
Monitor outputs are intended for stage monitors and vary ONLY with the monitor controls at each channel and the monitor sliders and do NOT vary with the sliders.
Aug 27, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How to get the effects to work on the mixer
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
May 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have a beringer eoropower pmp 5000. i run my mains and monitors in mono how do i turn the volume up for my monitors
With the AB switch at the center position Mon1/Main you control the volumes INDIVIDUALLY with the MON pot for each input that is a couple positions above each of the input sliders.
Aug 26, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
136 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
