Question about Microsoft Windows XP Professional SP2
I want to print from my pc (Secure NAT Client)to a printer on a deffirent network. My pc can ping the printer but is unable to print documents. The ISA Server 2004 Firewall may be blocking this.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
Check in the your setting internet sharing computer in there you setting about permision with other network.good luck
Posted on Apr 27, 2010
Does not seem to print xps files.
For sure, you're trying to print a document or text from a client PC in which the print network was not shared. If this was the case you can try these simple 1-2-3 steps:
1. In the server make sure that the printer is shared through network thru the Printer and Fax Config in the Start Menu
> Select Printer
> Properties
> Sharing
> Share this printer (Printer name ex.: Brother...)
> OK
2. In the client PC make sure that the printer is joined through the network thru the Printer and Fax Config in the Start Menu
> Add A Printer
> A Network Printer
> Connect to the Printer (ex.: \\server\Brother...) Automatic Detection...
> Next.....
> OK
3. Ready to print any files....
Jun 16, 2011 | Brother DCP 165C Compact Color Inkjet...
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Brother mfc-465CN on LAN but will not print. Has done in the past but suddenly stopped. On printer control panel it showed as being unavailable. Other PC's on network print to it ok and the problem PC can...
can you ping your printer from that computer? if not then can you ping other computers on your network? If not then there is something wrong with your computer network on that computer.
Nov 23, 2009 | Brother MFC-465CN InkJet Printer
DP-300 Print Server Access Problem
Using a print server like this, you should not need to "browse" to find the printers. See what ip address has been assigned to the printer. Once you have the ip address, open a command prompt (start -> run -> cmd) and type:
ping <insert ip address>
ex: ping 192.168.0.24
See if you can ping the printer from each of your computers. If you can, great, install the new printer by adding a "local" printer at a new TCP/IP port with the IP address of your printer. If not, then you may have some routing issues.
Are all of the printers connected to the same switch? Do you have multiple "routers" on your network acting as DHCP servers?
Hope this helps.
May 27, 2009 | D-Link DP 300 (DP-300) Print Server
New Epson TX101 cannot print from network
'why i cannot cannot connect printer my network have some alitle bit computer that cannot connect and other can. I already check Computer Name, IP and WORKGROUP. but when i ping to computer that has printer it work. How should i do about this or this printer share only alittle.
May 13, 2009 | Epson Computers & Internet
Client PC not able to ping WAN networks
Did you set reverse routing rules on the D-Link?
Dec 18, 2008 | D-Link DFL-800 Firewall
Please Help
How is the printer connected through your pc? Is it wireless, wired network or USB cable? If it's wireless, check if the printer is connected to the network. Ping the ip address. If replies, check the printer ip on printers and faxes and make sure it matches the ip on the printer itself.
Aug 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
Microsoft Windows XP Professional SP2 Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
