Question about Polaroid 15'' HDTV Monitor FLM-1511
Do plasma televisions need to be recharged regularly? Picture initially comes on, then pink and white lines scroll down the screen and wipe out the picture. Sound still works. TV is only about 2 years old. Really not impressed with Polaroid.
    Problem Solver:
  • 8 Answers
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Posted on Jul 12, 2008
Pink horizontal lines on samsung plasma tc when white background
I have this same tv and have the same problem, anytime there is a white background there is this pinkinsh tint in the middle of the screen, easily seen during those Apple commercials.
Aug 13, 2012 | Samsung 3D Plasma TV PN58C8000YFXZA...
Pink color horizontal lines comes on and off
That issue is with one or more of the board that drive the plasma screen. If you have a warranty, you will want to call LG for a free repair.
Sorry, but to trouble shoot that issue would require some TV tools and knowledge of electronics. There are several boards involved with processing the picture image to the plasma screen.
I hope this information has helped you.
Good Luck.
May 24, 2010 | LG 50PS60 50 in. Plasma HDTV
I have a pdp4247 plasma i have a 3" white line down the center /w
there are no bulbs in plasma tv's. the problem is most likely a bad video board (what converts the digital input to usable picture for the screen) it will need to be replaced, probably better to get a new tv.
May 21, 2010 | Akai PDP4225M 42 in. Plasma Television
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Sep 18, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Polaroid 15'' HDTV Monitor FLM-1511 Logo
70 people viewed this question
Top Polaroid Computers & Internet Experts
Larry Maranto
micky dee
Tom Chichester
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
