My Samsung T/V Model UW21J10VD Has a gap of 1.5 inches on the right-hand side of the screen I have Adjusted the Service menu ADJ. to no avail, Can you help please. tvted.
  • Edward Jones Apr 26, 2010
    Yes,the P/S voltage is down by 12 volts, will work on this next week.
    Many thanks,
    tvted.
  • 12,061 Answers
If you cannot, adjust out the size of the screen, then perhaps your powersupply isn't outputting the correct voltages, or some component has altered in the with circuitry, there are a few components, that have an effect on the width, first of course we have the Width control circuitry itself, then we have the Scan circuitry, and the PSU, Also it may be a timing problem. You need to have look at the signal, to the drive, with your oscilloscope, and most likely you will find, a crushed down signal, i would suspect, possibly a low value, higher voltage, electrolytic capacitor, or perhaps even, a badly biased diode, that is causing loss of signal to the drive. or as said, the power rail, maybe slightly low, Also it maybe the actual IC, suppling the signal, again, it is probably low, usually, as said it is the screen voltage/current that will not allow the scan completely out to the edge, actually you should be able to get at least a 10% overscan, anyway. have you tried a reset, also are all the shields on?
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/UW21J10VD-_E
http://www.scribd.com/doc/26351010/Samsung-Lcd-Lb350-650-Training-Book
Samsung lcd training manual. http://elektrotanya.com/samsung_bordeaux-19_lcd-tv_training-manual.pdf/download.html
Posted on Apr 25, 2010
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Turned back light down on my polaroid 4GB pmp280-4 touch screen now i cant see to turn it back up
settings is in the lower right hand side of the screen, tap there.
display is in the middle of the screen on the left hand side about one(1) inch down from the top of the screen.
the slider for brightness is down one and one-forth inches down from the top of the screen, tap about 1 inch from the left hand side of the screen, remember it is 1 1/4 inches down the screen.
NCMB
Jan 22, 2011 | Audio Players & Recorders
Frost build up shortly after defrosting it.
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Jul 10, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
The screen is not lineing
Depends on what make and model you have. If you have a Samsung projection TV, you only have to adjust the DMD board (Digital Mirror Display). If you have a Zenith or Sony projection TV you must adjust the projection lens.
Mar 25, 2008 | Televison & Video
SHADOWING
jesus have you move that tv thats new to me but surely techman know about.....good luck
Aug 08, 2006 | Optoma RD50 50" Rear Projection HDTV-Ready...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
