Question about Refrigerators
Kenmore side by side is leaking water from bottom freezer portion.
I have a Kenmore Model: 10652274202 Kenmore Side by Side.
Every now and then from left bottom side of the door where it is the freezer, it leaks water, and can not find the source.
I have my dispenser is broken and not working for 2 years, so that can not be the cause and took every thing out and could not find a ice water pipe so I can tap it in case the water circulation is iced up.
Can you help to fix this problem?
Thanks
My phone number 818-489-2801 and email
[email protected]
  • Anonymous Aug 27, 2008
    leaking water on bottom of freezer, every second day this happens
SOURCE:
  • 237 Answers
SOURCE: My Jennair Side by side has ice in freezer bottom and leaks water
This sounds like the defrost drain line is clogged and frozen. Every 8-12 hours the defrost cycle melts the ice buildup on the coils and is supposed to drain out to the pan under the fridge. Once this is blocked or freezes up the next cycles continue to put liquid water over the existing ice which then freezes, etc. till finall the area is frozen enough for water to find it's way out the door seals. You will need to take the back interior panel off the freezer side to view the coils and drain line. It will take lots of hot water to melt the ice in the drain area and the drain line in order to run a cleaning tube (basically a piece of 1/4" tubing like the water line tubing a couple feet long that you can force down the drain to make sure it's not plugged). Once you push the cleaning tube down the drain and can see it come out the other end in the drip tray pull it back out and pour hot water down it once more to watch that it drains fast. That should do it!
Posted on Feb 08, 2007
  • 23 Answers
SOURCE: water leaking from bottom of refriderator
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Posted on Dec 07, 2007
duby1990
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
larryyb
  • 291 Answers
SOURCE: Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Posted on Nov 25, 2008
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
Why does Ice build up at the bottom of the freezer side of my Kenmore side by side refrig model # 106.54602300? Purchased in 2003 Thanks Mark
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
I have Kenmore refregrator model 51272200. Water is leaking inside and forming ice at the bottom of the freezer. The refregrator compartment is warmer than usual. Your help on this is greately appreciated....
CK THE ICE MAKER WATER INLET TUBE IT MAY BE ICED AND CAUSING THE WATER TO RUN DOWN THE BACK / ALSO CK THE DRAIN IN BOTTOM OF FREEZER / A VERY COMMON PROBLEM . THIS WILL ICE THE BOTTOM OF FREEZER FLOOR AND RUN OUT ON FLOOR .. .. MM HOPE THIS HELPED ..
Jul 01, 2010 | Kenmore 53092 / 53094 Side by Side...
I know this is strange but here goes. I have a Kenmore Coldspot side by side Refrigerator. This past summer, it was leaking water out the front freezer door. We turned off the water and called a repair...
Turn off the fridge. Remove the freezer bins in the bottom. Defrost the drain line with a hair dryer.It is on the lower back portion of the freezer. Break up the ice on the freezer floor and dispose of it.
Discard any old freezer food. Change out the water supply line with a copper line if you are using a plastic line.
Dec 23, 2009 | Kenmore Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
302 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
