Question about Kitchen Appliances - Others
Jet Steam Oven
I have never used one. I purchased a fairly new one at a garage sale. No instructiions included. Can I prepare ribs in this oven. I need to prepare a dish (ribs) from there I think I prepare anything. Question is there a manual for this jet steam oven on the internet? Do I add water to the bottom? Place on rack and let it steam or what? HELP
NO YOU DO NOT ADD ANY WATER... JUST SEASON OR MARINATE THE RIBS AND PLACE THEM ON BOTTOM RACK AND PUT OTHER RACK ON TOP AND COOK FOR MAYBE 8-10 MIN....THIS THING ROCKS
Posted on May 28, 2010
How do I LIGHT THE OVEN
being gas , open the oven door
push the oven knob i and turn at the same time
the gas should start and at the same time a spark will occur at the gas jet to light the oven
how to use is included in the user manual
May 15, 2016 | Ovens
Replace door latch on sharp microwave R-520KS
Sorry but its probably not worth it - consider cost of the part + cost of labour and you could probably buy a brand new machine.
Otherwise look out for a used machine from your local 2nd hand store, garage sale, refuse tip etc and get the part from that and do it yourself - MAKE SURE ITS UNPLUGGED.
Jun 08, 2010 | Sharp R-520KS Microwave Oven
How to replace oven igniter on amana ACS3350AS gas range
The following link explains step-by-step how to replace an igniter in a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The replacement process is pretty standard with nearly all gas ranges. You can go to appliancepartspros.com for reference drawings to assist you as well. The oven burner assemblies are listed under the "Cavity" section.
If you have not purchased an igniter yet, the part number is AP4041245. If the connector plug does not match, there should be instructions that direct you to splice the wires using ceramic wire lugs. DO NOT use standard wire lugs. They will melt due to the high heat in the oven. The wires and connectors on these oven igniters are heat resistant. If ceramic lugs are not included with the igniter, you may have to purchase them separately. The part number is AP3440631.
This is a fairly simple repair, but if you have questions, please let me know. I hope this helps you.
Nov 15, 2009 | Amana RanARG7302 Gas Kitchen Range
Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Jun 30, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidarelectstoveglfs76aqhsetovenclenar
Self-cleaning ovens are the easiest type of oven to clean. Simply remove the oven racks, it should be fairly simple.Take everything out of the oven, including the grill. At the top of your oven door, there should be a latch. Lock that, then look on your setting dial. There should be a self-clean notch on it. Turn your dial to that and let it do its thing: The timer will shut it off and unlock the door when it's done.
set your oven to the cleaning mode, then wait a few hours. After the cleaning cycle is complete, you will need to wipe up the residue inside the oven with a damp cloth or sponge. While your self-cleaning oven is doing its job, take time to scrub down your oven racks with a steel wool detergent pad. The exterior of your oven can be cleaned with a sponge. Use basic window cleaner to clean and shine any glass or chrome areas.
If your oven is not a continuous or self-cleaning model, you are in for a little more work. Make sure you have rubber gloves (the longer, the better) to protect your skin from harsh cleanser. You will need to purchase a cleaner specially made for cleaning ovens. Be sure to ventilate the room well as these types of cleaners give off potentially harmful fumes.
How long you leave the cleaner on the interior of your oven will depend on the directions on the can. Most oven cleaners will need to be left on for several hours or overnight, others explicitly state that it should not be left on for longer than 2 hours. When removing the cleaner, be prepared for a lot of scrubbing and rinsing. You will want to ensure that all the oven cleaner is removed from the oven before use.
Perhaps you don't want to use harsh cleansers on your oven. In this case, you will find that a simple mixture of white vinegar and baking soda can do the job. Lightly moisten the interior of your oven with water. Then, apply a thick layer of baking soda. Allow the baking soda to sit for about three hours.
After three hours, spray the entire oven with white vinegar in a spray bottle. You will notice that when the vinegar hits the baking soda, fizzing occurs. This fizzing action helps remove stuck-on mess almost as easily as any commercial cleaner. Allow the vinegar and baking soda to sit for a few more hours. Then, simply remove with a damp sponge and some water.hope this helps pls apreciate with a fixyaa rating thanks and Godbless
Jan 13, 2009 | Frigidaire FEF352 Electric Kitchen Range
Electrolux Oven
if the fan inside the oven cavity is operating as well as the light, then the problem is probably the circular element is open circuit.
get back to me if you want - fairly easy to fit and not too expensive
Jun 23, 2008 | Electrolux Ovens
Door Window steams up on Microwave
Is the internal cooling fan running? You should feel air flow from the grille in the front or back (as the case may be).
If it's just steaming up the inner face of the door, that's fairly normal, but if the steam is appearing inside the layers of the door, that is not normal.
Since it's new and you've got a warranty, I would call Emerson.
Nov 02, 2007 | Emerson MW8107WA Microwave Oven
Kitchen Appliances - Others Logo
190 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
