Question about ASUS P4P800-MX Motherboard
Chassis Intruded Fatal Error System Halted! How can I bypass this problem?
    Novelist:
  • 128 Answers
The pc lock has been activated. A keyboard has a set of lock pins on it that is right in the same pin group as the pwr switch, reset, spkr....ETC... It is there so that if someone wants to make sure that the case of the pc is not opened they connect the pins to a lock. It is there to secure the info on the HD, or to keep theives from taking ram or video cards, ETC....
it usually is just sulkscreened as "lock". The bios hsa a secruity setting to activate the lock. Make sure that the pins for the lock are not connected to a lock, and go to your bios by pressing the del key or F1 key on bootup and make sure that the lock is deactivated..... Thant should solve it, If worse comes to worse, find the BIOS reset jumpers and short tem out, this will reset the BIOS to factory settings, which by default is "UNLOCKED"
Good luck,
James.
-----Please click on some thumbs up 4 me!!!!!--------
Posted on Apr 25, 2010
Does this always appear on the screen?
First of all, make sure your Unit is not prone to bumps or can have contact to any metal. I have encountered this problem when I forgot to put the chassis cover back, so i put it when the computer was running. So I just Long pressed the Power Button, attached the cover, then started my computer. It works just like before.
Dec 04, 2010 | ASUS P4P800-MX Motherboard
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Jul 24, 2010 | ASUS P5V800-MX Motherboard
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Dec 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
Apr 07, 2009 | ASUS A8R32-MVP Deluxe (A8R32MVPDLX)...
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis Intruded, Fatal Error.....System Halted
I'm not familiar with that particulat model, but I'd guess the motherboard has a chassis switch connector, and senses the chassis be open. Could be because: - chassis open (close it), - switch defect (as a workaround, you could short-circuit it, or just unplug it - whichever solution works for you). As another workaround, you can probably disable this switch in BIOS.
ASUS P4P800-MX Motherboard Logo
962 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
