Question about Compaq Armada 110 Notebook
I have bought a PIII 1Ghz CPU to replace my armada 110 Celeron 700MHZ CPU, Sometimes it works well for about an hour then just turn itself off, other times only lasted a few minutes. I've noticed that the fan has been running quite hard as soon as I switched the machine on, I wonder if the problem is with the slight different working temperature of the two CPU or the FSB frequency is not set right? the original Cpu is SL4P2 , and the 1Ghz is SL52R. please help me out if you can, thanks
  • Adnan Bhatti
    Adnan Bhatti May 11, 2010
    Please refer to the datasheet of the motherboard and see if the processor is compatible. If it is then reseat the processor ensuring it is making contact with the heatsink and the thermal paste is not peeled.
    Problem Solver:
  • 7 Answers
With out knowing your motherboard it's a guess. However you can look at the link below. Then scroll to the bottom of the page. Your SL52R should be the 4th cpu from the bottom of the list. It doesn't look likely and it definitely runs hotter. http://www.cpu-upgrade.com/CPUs/Intel/Pentium_III/RB80526PY700256.html
Posted on May 30, 2017
5 Suggested Answers
Blue Hammer
  • 167 Answers
SOURCE: CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Posted on Oct 02, 2007
eagle338
  • 4889 Answers
SOURCE: Acer Aspire 3683NWXCi. - CPU: Celeron M 430 1.73GHz, 1MB cache, 533MHz FSB
The driver for all of the 3680 series laptops is same...
Here it is....
http://support.acer-euro.com/drivers/notebook/as_3680.html
Posted on Oct 17, 2007
SOURCE: Lap Top Automatically Goes into Stand By Mode
needs either a new battery or power cord
Posted on Nov 06, 2007
  • 14 Answers
SOURCE: compaq presario cq60 no display
have you tried plugging in the laptop to a pc monitor ?? this will tell you if its your screen or there are other problems with the laptop please let us know if this helps ok
Posted on Jan 31, 2010
Is there a cpu upgrade for an hp pavilion 6835 with a motherboard 115561 cognac 20000731
The fastest Pentium 3 that will work in your board is a Intel Pentium III 1GHz chip. Here is a link to the specs:
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201000%20-%20RB80526PY001256%20%28BX80526F1000256%29.html
You could also get a Intel Celeron 1.1 GHz but it only has half the level 2 cache size so it's actually a bit slower than the Pentium III 1GHz chip.
Here's a link to celeron specs:
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20%28BX80526F1100128%29.html
May 23, 2012 | Powerleap PL-NEO/T Celeron, 1.4 GHz...
Dell laptop model ppo1l in which year it is manufacture
Hi.
Latitude C600 was introduced in ~2000.
700Mhz CPU was then upgraded to 850Mhz the same year and 1Ghz in 2001. The series was discontinued in 2002.
Hope this helps,
Raf
Nov 14, 2009 | Dell Refurbished Notebooks: Latitude C600...
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
My Screen Is Black When I turn the Laptop On
need a inverter maybe. t23 lcd inverter check ebay diy project need a screw driver thats it
Apr 14, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
CPU Upgrade
You pulled the processor out of your laptop ... that was a brave move ... generally laptop boards are fully integrated so there is very few options on changing the processor ... also because of the extreme heating conditions the heat sink bonding is very critical ... make sure you replace this properly or you will have overheating issues in the future ...
Mar 30, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Toshiba 4600 - replace P3 700mhz with P3 1ghz
No you can't pull out as the CPU is surface mounted soldered on the mainboard, only manufacturer or approved repairer can take it out and put the new CPU with only the correct voltage specs.
don't try yourself otherwise you will damage the entire laptop.
Dec 12, 2007 | Dell Inspiron 1100 Notebook
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Oct 31, 2007 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Oct 01, 2007 | Compaq Armada M700 Notebook
CPU Upgrade Help Compaq M700
You might want to check this out I think it answers the questions you are asking? http://h18000.www1.hp.com/products/quickspecs/10382_na/10382_na.HTML
Sep 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada 110 Notebook Logo
49 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
