Question about Refrigerators
My refrigrator high cooling in the frezeer and very low in the lower side, What is the problem please?
  • Nabil Hadi Apr 25, 2010
    Thank you for your help i did a troubleshooting and found that deforest timer does not rotate due to some gears were broken
    my best regard
When this happened to my side by side it was the defrost heater that needed to be replaced.
Posted on Apr 25, 2010
2005 vw jetta why won't my high side high pressure go down
I assume you are talking about your a.c unit, if so the high side pressure takes a while to go down after turning a c off, it its too high it is either overcharged or there is a restriction
Oct 14, 2015 | Cars & Trucks
Now use refrigrant 410a .but i dont no how mach puting gass unite in side. and how mach prassor high and low comming.
In order to do anything related to R-410a refrigerant, you need to be certified by the EPA. The fine is $30,000 for non-compliance. Please call a pro. I will not advise.
Welcome To the Best HVAC
Oct 08, 2014 | Heating & Cooling
Can you add refrigerant to the refrigrator. it is not cooling like it should. this an olser refrigrator side by side kenmore..934163-D
you can add if needed . but this is the last thing to do for your problem . do ck the fans and air flow first . also the derfrost system these are more common for a no cool problem .. mm
Aug 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
A dealership fixed my cooling system. I was told it was an airpocket in the system. Now my ac only blows hot air. They keep putting me on hold and its hot outside. any ideas?
if the low side tube is cold while the compressor is working the problem will be on air door module, or one piece of hose from intake manifold go to recirculation door is dis connected, but if he compressor is not working, there is only two reason, even the refrigerant pressure is too high or too low, if low a leak on your system, if too high overcharge or clogged expansion valve or the condenser, if refrigrant is i the right pressure and compressor is not working, check the supply on main switch, ambient temperature sensor, refrigrant pressure sensor and the high pressure sensor, if all ok,. replace compressor
Aug 05, 2010 | 1989 Ford Crown Victoria
Rear seating air conditioning will only blow hot air 1998 Ford wi
you need to change out the capilay tube on the rear and the reciever dryer.
Jul 09, 2010 | 1998 Ford Windstar
Hello I have carrier frezeer and it is not working gooc? The ener fans are working but the compressor is not working. checked all breckers were ok and I do not have any electric drawings the unit model #...
if the compressor buzzes periodically but doesnt start then that would be a bad "starting capacitor" (usually mounted on or near the compressor with wires to the compressor .. if the compressor runs but no cooling then thats low refrigerant (it has to be recharge) ..
Dec 23, 2009 | Freezers
The refrigrator sution line keep's freezing and wont cool lower than 44 degee's. what should i do to get my temp down and keep the line from freezing? Also what should the high side pressure and low side...
Im taking it that you have recently had work done on your fridge. What you are telling me is the system is overcharged by a fair amount. Decant by removing small amounts of gas from the service port which in effect "should still be on."Depress and Remove in 5 second intervals then stop and wait for approx 10 min. If ice is still there carry on that way untill ice is no longer on the suction line. If the evap. is flooded, cooling is lost. On the small compressors, do not worry about the high side pressure, you normally charge to -15 deg. celcius. at your ambiant temp. .
Sep 23, 2009 | Traulsen Refrigerators
Ac not working cuts on and off when aux fans turn on. what could be the problem?ac was working fine, now it blows really low cold air then blows hot air.
i assume u r refering to the cooling fans,,, if this is so the freon is low ,fans come on and lower the high side ,there fore lowering the low side and the low side switch cuts it off and on,,charge it up
Jun 29, 2009 | 2002 Nissan Sentra
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
