Sony KV-29CL11K won't power up (11 flashes) - Televison & Video
  • 10 Answers
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on Apr 25, 2010
TV SONY KV-29CL11 / K is difficult to include in the text (35 times the POWER button) to get involved.
Red light flashes on stambay 11 times. Thank you in advance.
Posted on Feb 17, 2011
Hi, i have a problem. My Sony Trinitron (kv-29cl11k) tv tries to turn on and then click out and the stand-by light just blinks. This has been getting progressivly worse. It is like a relay will not stay...
11 blinks do not occur to Sony Trintron TVs. It should be 10. Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. If you wish to get more details about these blinks, check the site linked here. Blinking codes and fault detection to many brand TVs, including Sony are given in detail. These blinks are called, blinking codes, and fault indications. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. Check the site, and get more details. http://electronicshelponline.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 28, 2013 | Televison & Video
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
11 times LED flashing
call sony tech support...sounds like power board
Jun 01, 2010 | Sony KV-XJ29M50 29" TV
Trinitron 36" led flashes 11 steady flashes then 5 quick.
Hi
You have defective power oscillation in power circuit! this need to diagnose to find the bad parts!
Thanks!
Oct 18, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
SNY tRINITRON
the tele is a kv -29l s3u and flashes 11 times and pauses then does it again can you tell me what this is. any help would be a big help thanks lenny or can you tell me if its repairable
Jun 16, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Sony KV-28HX15U
Most likely the flyback assembly, and or the horizontal output transistor failed. There is also a possiblity of some other faults that are putting the power supply in to the protect mode.
If there is a scan failure, it is possible that there is also some damage in the power supply.
The set will have to be serviced by a TV service tech.
Jerry G.
Apr 13, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Aug 06, 2007 | Sony KV-DR29M69 29" TV
Televison & Video Logo
2,016 people viewed this question
Top Televison & Video Experts
Electro Med Services...
