Question about Sony Ericsson W600i Cellular Phone
Lcd screen light wont work
I can see the screen dimly, but the screen does not illuminate. the keys dont illuminate either but the phone does recognize when I swivle it open. the battery charge light works and the camra flash works. would buying a new screen for it be wise or does the problem lie some where else.
    Brigadier General:
  • 7,752 Answers
What you should do try a flexcable and see if that helps if not then replace it with the LCD.
Posted on Mar 23, 2008
I got samsung laptop R580, the screen broke because of falling so i ordered online, and replaced it with new one myself, it was working fine for two weeks but after two weeks the screen went very dim! I...
The inverter could be faulty. The inverter supplies high voltage to the CCFL lamp that provides the back light. The inverter is located at the bottom of the LCD screen between the hinges.
Sep 09, 2012 | Computers & Internet
Cva 1003 STERIO. (ALPINE) i dont have illumination wires, will this mean that my sterro wont work?
that just means that the backlighting for the display will not switch on and off, or dim, with the dashboard lights, the display will be lit all the time.
Mar 12, 2011 | Car Audio & Video
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
Fujifilm Finepix F30 compact digital, LCD is very dim.
its not a good idere to get them wet you know,
it could be repaired if you can strip it out and you may be lucky it could only need drying out to work again take care when striping it down dry it out in free air only dont apply ant heat to it
Oct 31, 2009 | Sharp Viewcam VL-AH130U Camcorder
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
My laptop is very dark and holding fn and the sun
The Back-light on your LCD screen is bad, your crystals aren't illuminating, so it is dark.... very dark.
You need a new LCD screen.
Sorry.
Sep 24, 2009 | Acer Aspire 5500 5570-4421 Laptop
Display problem dell c600
I've also had that, The FN and brightness I've not determined, as I changed LCD panels, however, components in the LCD screen can be swapped out, cable and inverter and backlight (<-very hard to do!!) and the ATI graphics board is mounted to the mainboard, for the C600 they are affordable
Dec 20, 2008 | Dell Latitude C600 Lcd LCD Display
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
N95 screen illumination
Did you check thIs?
I.Menu...tools...settings....general..light sensor.....Try to increase the light sensor .
2. change the lcd????
Aug 07, 2008 | Nokia N95 Cellular Phone
Dim light on my sony vaio.
heres the solution! if ur fn + F5 key doesn't work...
1. go to start
2. go to control panel
3. click "power options" has a pic of a battery
4. click "change plan settings" under "balanced"
5. change "adjust display brightness"
May 23, 2008 | Computers & Internet
Sony Ericsson W600i Cellular Phone Logo
69 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
