Question about Sanyo DS27930 27" TV
I have a 2004 Sanyo flatscreen tv model DS27930. My daughter pushed scan on the remote and now the tv screen says 'first please connect cable system or an antenna to the terminal on the back then press the menu key'. I only have my tv hooked to my playstaion and it wont let me do anything it just has the blue screen with those words. How can i get my tv back to normal so i can play my play station again. Even if i unplug my tv it wont go away i don't know what to do to fix it.
  • 2,335 Answers
I can help you with your Sanyo DS27930.
Pressing the RESET button twice on your remote will restore factory settings, and as you are finding out will start the Channel Search 'feature'.
The manual states that if you ignore the search prompt for 15 minutes, it will turn itself off and stop trying.
Alternately, just press MENU like it is asking you to, and let it waste its time searching for 150+ channels of static; when it is done, it will stop.
I hope that helps.
_________________________________
Sanyo DS27930 Manual Download
Posted on Apr 26, 2010
I have a Sanyo HD flat screen model DS27930 and I'm not sure how to hook up my XBOX 360 to it. ;3;
On most flatscreens there is around four HDMI inputs. Any of these should work. The HDMI should connect from the Xbox to the HDMI input on the TV which is usually on the side of on the back.
Jan 29, 2016 | Microsoft Xbox 360 Console
Sanyo tv model ds27930 not supporting my ps3
Whatever input you are using is either damaged or the tv is on the wrong channel and I'm sure you don't have it set on the wrong channel.
1. Another method would be to connect an old VCR to the TV through the cable plug on the back of the TV.
2. Then plug your PS3 or dvd player into the VCR's rca inputs on the back.
This works but your television has to have a cable plug on the back.
Oct 16, 2013 | Televison & Video
Can get tv to change to av1
The Input button on the original remote is needed to switch to the AV1 or AV2 connections. Unfortunately, I do not believe that the Sanyo DS27930 has an equivalent Input button on the TV. A replacement remote is available here: http://www.emtcompany.com/sanyo-ds27930-remote/rc64.html . Other universal remotes may be able to transmit the Input signal. You will need a remote that was programmed over 6 months after the TV was released with an Input or Source button. Then try all Sanyo codes until you find one that controls all of the features.
I hope this helps.
Mar 04, 2013 | Sanyo DS27930 27" TV
SANYO REMOTE MODEL: FXWD - PROGRAMMING MANUAL
The Sanyo FXWD remote was used with the Sanyo DS27930 and DS32424 TV. The manual for the TV is available at manualslib.com. The instructions for the remote are on pages 7 thru 11 of the TV manual.
Mar 28, 2012 | Televison & Video
DS27930 27" TV: I have a Sanyo DS27930 tv and the remote hasn't ha...
check the remote control for any rust on the contact terminals of the dry cells.If present sratch it off and place back the cells and see if it operates.if it does not work you can easily identify the between the tv or the remote what is mulfanctioning by testing the remote for ir radiation,simply by directing the remote to a camera sensor of your mobile phone,if ir light is seen as you press the buttons then the remote is good and if not then the remote is faulty and might need technical expertise to repair.however if you see the ir light ,the problem lies with our set
May 18, 2010 | Sanyo DS27930 27" TV
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
DS 27930 remote control
My problem is this TV of ours does not work now so if I cannot get it fixed I guess you can buy our remote control.
Doopey
Feb 17, 2008 | Sanyo DS27930 27" TV
Need original remote
Not sure, but have you tried getting a universal remote and programming it with a sanyo code? If this is not an option you can get MFR. remotes on ebay, but they might be costly. I went to ebay and did a search on "DS27930". I found one seller, but there was a least one. $34.95 for a remote sounds high to me.
http://cgi.ebay.com/Sanyo-FXWK-DS27930-DS32424-DS32920-DS36930-6450610165_W0QQitemZ5846882733QQihZ012QQcategoryZ15065QQrdZ1QQssPageNameZWD1VQQtrksidZp1638.m118.l1247QQcmdZViewItem
Feb 10, 2008 | Sanyo DP19648 19 in. LCD TV
Universal remote codes
i need remote codes for a star choice remote to be used on a sanyo DS27930 27" tv please help
Dec 23, 2007 | Sanyo DS27930 27" TV
No progressive scan from component input
Sanyo DS27930 does not support progressive scan
DVD player must be set to interlaced scan
Nov 24, 2007 | Sanyo DS27930 27" TV
Sanyo DS27930 27" TV Logo
139 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
