Question about Hoover AAA140 Front Load Washer
HOOVER LOGIC 1300
Hi
My washing machine will not spin the full cycle, water is still left in the machine on on most wash cycles. Can someone help.
Thanks
  • 1 more comment
  • DOLPHIN52 Mar 23, 2008
    HI
    MANY THANKS FOR GETTING BACK WILL TRY THIS OUT IN THE MORNING.
  • DOLPHIN52 Mar 24, 2008
    HI TECH17
    BRILLIANT ADVICE PROBLEM FIXED FANTASTIC WORDS CANNOT DESCRIBE MY FEELINGS. THIS PROBLEM HAS BEEN GOIN ON FOR OVER A YEAR. WE WERE GOING TO BUY A NEW WASHING MACHINE IN THE EASTER SALES BUT WILL BE SPENDING THE MONEY ON A BREAK TO BARCELONA.
    LYNN
    PS THINK I WILL SACK THE HUSBAND AS HE IS NO GOOD AT DIY, FANCY A DATE.
  • tdw101 Dec 28, 2008
    1. m/c does not spin on wash cycle. when put on 'g' rotates for a time then stops, the pump continues,but the programme sticks.
    2. after a time.say 2 hours,try again, it works,spins to completion.this possibly suggests a blockage has drained? your comments are wellcome.
    President:
  • 1,314 Answers
You need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Posted on Mar 23, 2008
Help my hoover w/machine will not agitate or spin.
ok does that mean u know how to bypass lid switch so u can see the agitator and bowl while it is cycle? normally when the lid is lifted the machine stops.sorry to ask u this question but it will help in fixing your unit.please reply 4 more help.
Apr 15, 2010 | Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
After the washing cycle it stops. It will not
HI, i would try a hard reset in this case. unplug the unit for five minutes. this will reset the logic sectors. if this no spin issue continues, replace the motor control board.
Sep 21, 2009 | Whirlpool Washing Machines
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Hoover AAA140 Front Load Washer Logo
1,013 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
