Question about Sanyo DS27930 27" TV
My Sanyo tv model number ds27930 has a blue screen that says "to connect a cable system or an antenna to the terminal on the back then press the menu key". I don't have it hooked up to cable just to my playstation 3 and even when i unplug it it still has the same thing on it when i plug it back in. How do i get rid of it so i can play my playstation again cuz it wont let me do anything at all.
  • dkg_kri Apr 26, 2010
    Thankyou very much!
  • Sanyo Master
  • 12,061 Answers
You need to try to connect to An EXTERNAL Input, NOT a Channel, you need to use the Remote, and try to select, the menu, and then the Inputs, select, the external, and there should be a picture. A "Blue Screen" is displayed when there is NO signal connected, from either the Antenna, OR An External Input. IF there is still a blue screen, and there is also NO menu etc, then you unit has a fault and needs to be repaired.
http://www.retrevo.com/support/Sanyo-DS27930-TVs-manual/id/311ci862/t/2/
http://sanyoservice.com/pdf/images/AVM2759S(SM780052-02,01).pdf Above service manual, above that your user manual.
Posted on Apr 25, 2010
Sanyo tv model ds27930 not supporting my ps3
Whatever input you are using is either damaged or the tv is on the wrong channel and I'm sure you don't have it set on the wrong channel.
1. Another method would be to connect an old VCR to the TV through the cable plug on the back of the TV.
2. Then plug your PS3 or dvd player into the VCR's rca inputs on the back.
This works but your television has to have a cable plug on the back.
Oct 16, 2013 | Televison & Video
Model ds31520. I've had it for years working like this: no antenna, no cable, just DVD (connected to non-S input ports) watching movies. Somehow I hit a button sequence on the remote and now only this: ...
Sorters -
Re-connect to me on the chat and we'll get this sorted. I'm really sorry - I got disconnected and the system would not allow me to reconnect to you. I have some ideas but chat would be easiest. If you don't want to chat, post a message here and I'll message back with some things to try.
BElectric.
Jan 22, 2011 | Sanyo DS31520 31" TV
Blue screen has audio can change channels and hear different audio but no picture
Hello
If you can see menu on-screen display, just get into it, surf for blue-back option and turn it OFF first, and see whether there is any grains appears on your screen. If there is no grains, and only a plane raster, your TVs video processor Ic has got damaged, and should need replacement. If there is grains, you just retune it in autotuning option, and allow it to store all the transmitting signals at that time. This process may take two or three minutes to complete, and you should wait till then. Never forget to connect antenna socket to the antenna terminal of your tv.
If you are using set top box, and connected it to the TV through audio-video cable, your TV has no fault, but the set top boxs' video processor has got damaged. OK,
Nov 24, 2010 | Sanyo DS31520 31" TV
DS27930 27" TV: I have a Sanyo DS27930 tv and the remote hasn't ha...
check the remote control for any rust on the contact terminals of the dry cells.If present sratch it off and place back the cells and see if it operates.if it does not work you can easily identify the between the tv or the remote what is mulfanctioning by testing the remote for ir radiation,simply by directing the remote to a camera sensor of your mobile phone,if ir light is seen as you press the buttons then the remote is good and if not then the remote is faulty and might need technical expertise to repair.however if you see the ir light ,the problem lies with our set
May 18, 2010 | Sanyo DS27930 27" TV
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
No picture on flat screen new, with cable
IF THIS IS A LCD---TURN ON, AS NORMAL AND HAVE A SIGNAL INPUT,,CABLE ,SATELLITE CONNECTED TO THE ANTENNA INPUT .MAKE SURE YOU HEAR SOUND.. HOLD A LIGHT (THE BRIGHTER THE BETTER) IN FRONT OF THE THE SCREEN ('BOUT 3 INCHES)--IF YOU SEE A DIM PICTURE---BAD SCREEN AND THATS BIG BUCKS---IF STILL NO PICTURE--CIRCUIT BOARDS AND USUALLY THATS BIG BUCKS!! GOOD LUCK
Mar 16, 2008 | Sanyo DS27930 27" TV
Can not get remote to change channgles
DISCONNECT THE VCR AND CONNECT THE CABLE STRAIGHT TO THE TV ANTENNA--GO INTO THE MENU ON THE SET AND FIND AUTOPROGRAM-ENTER THAT AND IT AUTO FIND ALL CHANNELS THAT YOU ARE SUBSCRIBED TO AND SHOULD PICK UP THE CHANNELS YOU SKIPPING!YOU CAN ALSO DO THIS MANUALLY--THAT'S ALSO IN THE MENU SCREEN..
Mar 09, 2008 | Sanyo DS27930 27" TV
No progressive scan from component input
Sanyo DS27930 does not support progressive scan
DVD player must be set to interlaced scan
Nov 24, 2007 | Sanyo DS27930 27" TV
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Sep 11, 2007 | Sanyo DS20930 20" TV
Sanyo DS27930 27" TV Logo
158 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
