Question about HP LaserJet 1022 Printer
Spooler problem - HP LaserJet 1022 Printer
  • HP Master
  • 12,061 Answers
OK, Go START>>RUN>>service.msc (enter) Now when the services window comes up, scroll down to Print Spooler, and select, ENABLE and Load at boot time. save and reboot.
Posted on Apr 25, 2010
My printer spoler is not working
Hi g k,
Have you tried restarting the print spooler from services?
Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler
    net start spooler
    exit
    Note Press ENTER after each command line.
Hope this helps, and please rate:)
Gary
Aug 01, 2013 | Samsung Office Equipment & Supplies
Print spooler is not running
Please try these steps:
  1. Browse to Start -> Run... and type NET STOP SPOOLER (this will stop the print spooler service)
  2. Type NET START SPOOLER (this will restart the print spooler service)
Try to print again to verify that the problem is fixed.
Feb 24, 2012 | Lexmark X1150 All-In-One InkJet Printer
Only printing 7%
If you're using Windows, it could be that your Print Spooler is not running properly. Please follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. type in NET START SPOOLER (this will restart the print spooler service).
Try to print a document again to verify that the problem is fixed.
Oct 10, 2011 | Lexmark X4650 InkJet Printer
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
Scan problems
Hi there
Print spooler is no less than the chief boss of printing action. Print spooler is a linking part between your PC and printing hardware. Print spooler is the only master of print department of your PC office. Print spooler is a master of all printing procedurees and it’s that what is responsible for the redress printing queue and serial printing of your documents. Any messages like “Spooler subsystem app has encountered” and “Spooler subsystem app stopped working” are a unfavourable sign that you have met printer problems and need facilitate. Spooler virus is not so wide spread but it can be a reason of printer spooler service keeps stopping. If printer spooler keeps stopping our tool is a best thing to sort it out.
Fortunately I know the program which can help you to eliminate print spooler virus without extra efforts. I see Print Spooler Fix Wizard as an optimal medicine for print spoolerWhen the whole province stopped because of corrupted print spooler function it’s significant to discover an trouble as soon as possible. Don’t wait a wonder from your printer – it’s nothing without its print spooler. It’s not required to find another place to copy any documents because you can cure your own printer with the assist of Printer Spooler Fix Wizard for five minutes.
Printer problems: is it an boring chance or a reason of why the whole department interrupts its earn money? When you end your earn money sending a paper into your printing waiting line print spooler only begins its earn money. Are you really sure that high-effectively your print spooler will ever hold out against print spooler virus? You needn’t activate to buy a up-to-date printer if you have Printer Spooler Fix Wizard. So fast and effectual treatment as Spooler Fix Wizard may become a salvation of your province printing capabilities. Just as you need your printer earn moneys now and printing tasks can’t be call off we suggest you Printer Spooler Fix Wizard.
You have a choice: try perennially to cure your print spooler by yourself or get Print Spooler Fix Wizard last and all the time. Doesn’t an hour of your work cost less than Print Spooler Fix Wizard? It’s better to get high effective solution for several minutes than try to cope with printer problems manually. When you choose Print Spooler Fix Wizard you decide successful help.
All the best Pineworks
Apr 24, 2010 | Lexmark X5650 All-in-One InkJet Printer
I do not seem to be able to print any documents even after uninstalling old drivers and installing new ones what is wrong
Apr 24, 2010 | Lexmark X1270 All-In-One InkJet Printer
Printer is not working.
Hi Surenderpdsi
It sounds as if the printer spooler needs re-starting.
This is the path to the printer spooler service,
Windows XP Path (category view)
Start – Control Panel – Performance and maintenance – Administrative tools – Services.
Windows Vista Path (category view)
Start – Control Panel – System and Maintenance – Administrative tool – Services.
Once in Services both XP and Vista are the same.
Look down the list till you find Printer Spooler.
Once found, right click your mouse on Print Spooler and select Properties.
In the properties box that open the service status should read “Started” if not click on start.
If it says the spooler is started click stop, wait till the spooler has stopped then click start.
This will re-start the spooler and should fix your problem.
Hope this helps,
MK Support.
Mar 15, 2009 | HP DeskJet 3745 Printer
PRINT SPOOLER NOT RUNNING
When I try to print, a notice appears that the printer spooler serviceing is not working.How can I solve this problem?
Jul 31, 2008 | Lexmark X75 All-In-One InkJet Printer
Printer Spooler service!
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP LaserJet 1022 Printer Logo
218 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
