Question about York Barbell Home Use Fold-Up Treadmill
ERROR 7 treadmill york model No LQ-6010 shows error 7 when turned on and wont reset or do anything else. please answer as soon as possible.
    President:
  • York Master
  • 832 Answers
Sounds like a incline problem , could be that the incline motor is stuck or the fuse may have blown on lower electronics.Call or E Mail:
Technical Support & Spare Parts OrderingCall: 01327 701824
Email: helpdesk@yorkfitness.co.uk
Opening Times: 9am-4pm Monday-Friday
Posted on Apr 25, 2010
My treadmill york show me in the sreen error 7 and I can to start machine it doesn't work .thanks gabriel
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Feb 08, 2017 | York Exercise & Fitness
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
York treadmill t-801la T780 platinum error code 1
see the comentary ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.7099b61f-975c-463c-9361-522952e1c927.gif
Run the software calibration for easy diagnostic and fix it. God bless you
Jul 08, 2013 | Exercise & Fitness
Error 7 on my york inspiration treadmill tried reset button but still not working any ideas.
hi,
By error 7 it means that the safety is not positioned correctly. or the saftey switch inside the unit is faulty. Its a magnetic switch. When you place the safety key (its made of magnet) this switch will activate. Then only teradmill start. Check the safety key is positined correctly or not. If it is in position then you have to replace the safety switch inside the control console.
OK
Sep 01, 2011 | York Barbell Home Use Fold-Up Treadmill
How i replace my york pacer 2750 safety key
I have misplaced my safety key for my York Pacer 2750 Treadmill and can no longer use it. Please help me find a replcement soon. The company York Fitness no longer do this model and don't have the parts either. Help....
Nov 28, 2009 | York Exercise & Fitness
My york treadmill pacer 3700 show error
I have just got a pacer 3700 off a friend and she had no manual for it. it keeps saying error 1 and wont do anything. what can i do to make it run again?
Oct 27, 2009 | York Exercise & Fitness
York t101 treadmill ls error
York treadmill T101 will not run has a error L5
May 11, 2009 | York Exercise & Fitness
Ls error
Showing l5 or ls on sceen of my york t101 treadmill please help me out thanks.
May 09, 2009 | Exercise & Fitness
Hi, have lost the manual for my treadmill York T500 treadmill. Error 7 keeps coming up...what does this mean please?
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
Apr 20, 2009 | York Barbell Home Use Fold-Up Treadmill
York t500 treadmill model no:LQ6010 showing err07 when turned on
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
York Barbell  Home Use Fold-Up Treadmill Logo
704 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
