Question about Furuno FCV-582L GPS Receiver
Furuno 582L The plugs on the back of my unit have broken and need replacement, Where and how can I get repairs asap?
  • CashORourke May 07, 2008
    The electrical plug and the transducer plug on the back on my FCV-582 Fish Locator have broken too. And the same plugs on my FCV-600 have
    broken too. Can I get replacements or get them repaired?
    Thank YOU,
    Cash O'Rourke (CashORourke@yahoo.com
    New Friend:
  • 132 Answers
Those jacks are on a circuit board available from Furuno call me if you like 847-746-0100
Posted on Jan 15, 2010
LCD coating needs to be replace or LCD REPLACED
Since you have little to loose you can attempt to remove the protective coating and not attempt to replace it with a substitute material. It's not required to operate but is intended to enhance viewing in certain light conditions. Might try a window cleaner with ammonia and a little "elbow grease". Remember though, your end result could be worse than what you have now if you're unable to completely remove the film or damage the JCD panel in the process.
Jul 14, 2010 | Furuno FCV-582L GPS Receiver
I have a furuno fcv 582l. The unit has just come back from the factory and works well until I power up any other electronic equipment on the boat. Then it flickers and the screen goes dark. Any ideas?
You likely have inadequate supply to your helm. Otherwise, there is interference being generated. Try turning things on slowly one at a time, check your batteries and ground connections.
May 15, 2010 | Furuno FCV-582L GPS Receiver
Can not get clear reading of bottom when travellling over 9 knots
Your in hull ducer is getting turbulence. (in hull or not) A transducer will stop working is the tiniest cabitation or air bubble interferes. If possible, relocate the ducer. If you have a transom mounted ducer, try angling the leading edge up. This is a 90 % chance caused by turbulence on ducer. The other possibility, al;though remote is that you alternator or ignition system is interfering after a certain RPM on the motor.
Try first to manually gain the FCV620. You will always need to manual gain set the unit if you have an in hull ducer.
Mar 02, 2010 | Furuno 520 Ihd Adj In Hull F/ 6000 600l...
May i upgrade furuno 1920 gps/ploter with radar
If it has a round radar plug in the back then the answer is yes and it already has radar support. However to upgrade your unit to the latest software you will need a dealer for that. It's a very tricky process and if not done properly, you can ruin the bootloader programming that starts the unit. I know of a dealer that does this if you want to check in with them. You can even send them the unit. Try www.mid-shore-electronics.com.
Jan 25, 2010 | Furuno NavNet vx2 1920C GPS Receiver
Data cards for Fununo 1850w
Furuno just stopped producing these models about a year ago. They use a special chart card. You can still purchase the cards from Navionics or C-map if you need to. I will tell you from experience that you should get your internal battery changed out if you havent done so already to keep from losing your settings and waypoints. The dealer will have to save them for you though and put them back on. Furuno made a GP7000 to replace this one and it's uses SDcards and is nothing like the rest of Furuno's product line. The best replacement for this unit is the Garmin GPSMAP 700 series. You can use your old furuno transducer if you have one (with an adapter plug). This garmin unit also has a built in GPS or you can use an external one. The 700 series will be shipped in April. Check out Garmin's website or mid-shore electronics.
Aug 29, 2009 | Furuno 1850w/Nt Gps Chartplotter C Map Nt...
Furuno 1621 radar will not power up
With a voltmeter, verify that you are getting 12V at the plug end of the power cable. If so, check the fuses (there should be one or two fuse holders on the back). If all of that fails you will need to send it in to Furuno for repair.
Aug 22, 2009 | Furuno 1715 LCD Radar System GPS Receiver
LLOKING TO BUY A REPLACEMNET TRANSDUCER FOR A FURUNO FCV-582L
Yes, the current model of this is the FCV 585 and it is great. The transducer will need to be changed.
Apr 07, 2009 | Furuno FCV-582L GPS Receiver
Trying to wire nav man gps imput into a 585fcv furuno echo sounder,i no the white wire of the nav man nmea output ,but what coulour wire is the imput for the 585,white and blue.but which one is the signal...
white and blue is correct, white is signal, but be aware that manufacturers screw this up all the time, so try it both ways, and look for pulsing data on digital meter measuring 12V, should see meter jump rhythmically, from 0 to 4-12V. Confirm presence of data to maintain sanity
Aug 17, 2008 | Furuno FCV-582L GPS Receiver
I have a furuno fcv 585 echo sounder with a FURUNO CA50/200-12M -c13298 BRONZE THRU HULL HIGH PERFORMANCE TRANSDUCER. The transducer has 4 wires and it looks from the schematic that it attaches via a...
you need an MB1100 matching box has the 10 pin pigtail for your sounder and accepts bare wire input from your ducer
this will also ensure that all power from sonar get to ducer, but it from me if you like 847-746-0100
Jul 09, 2008 | Furuno FCV-582L GPS Receiver
Furuno gps gp 32
The only place to get that screen is through a Furuno authorized dealer. The unit is sealed and gas filled to remain waterproof. You're best bet would be to send the unit in to Furuno for repair. You wont save much doing it yourself because the cost of the screen makes up most of the cost of the repair. They will also make sure that all the software is up to date for the new WAAS satellites that recently went on line.
Have you tried adjusting the contrast? On that model I believe you tap the power key while the unit is on and you will see 2 sliding scales on the screen, one for brightness and one for contrast. Up or down arrows select the scale and left or right arrows adjust it. If the contrast and brightmness aren't tied into the power key on that model, they're somewhere in the set up menu.
If adjusting the contrast doesn't help then the screen has most likely failed. This is commonly caused by old age, however repeated exposure to extreme heat or cold can cause premature failure.
Jan 25, 2008 | Furuno GP31 GPS Receiver
Furuno FCV-582L GPS Receiver Logo
276 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
