Question about Video Game Consoles & Games
I can connect it to my wii i need help connecting the verge wireless sensor bar to my wii
  • 51 Answers
Wireless sensor bars do not need hooked up to wii........it only acts as a camera device......it only needs switched on
Posted on May 01, 2010
Wii sensor bar wont work
try unpluging the cord connecting to the wii sencor bar for 30 sec.
Sep 19, 2009 | Nintendo Wii Console
Sensor bar inactivity on the wii videogame system
First you Should test with another sensor bar...try to take it from a friend to test it in your system...could be cracked wires from the sensor bar....try to test the wires with a multimeter and resolder the wires from the cable...or you can take your sensor bar and test it in another wii...you need to known if its really bad ,or if there is something wrong with your wii system...
Sep 09, 2009 | Nintendo Mini Wireless Sensor Bar for Wii
Wii remote will not work new batteries just blink all
Hey Jack, How many remotes are you able to connect at a time? If you have multiple remotes try turning the ones you know that work off, and putting them in another room(so you know they will not try to connect). Then try connecting with the bad one. If that doesn't work you might have to sync the remote: hold down the red sync button on the wii, located next to the sd card slot, while holding down the red button on the remote, located under the battery cover on the back. Now try connecting. If it still doesn't work, the LED lights in the sensor bar might have burned out, this happens a lot when you keep your sensor bar directly on your tv without the stand(the tv gets hot and burns out the lights), a lot of people do this because the stand looks bad. Go buy a new sensor bar, they sell them at wal-mart for $20, plus they're wireless, so you don't have to worry about that thin little wire popping. Test the new wii bar, if it's still not working, then you're remote is just worthy of getting returned.
hope this helps! -cj
Aug 21, 2009 | Nintendo Wii Console
No connection from remote to screen
Your sensor bar is definitely burned out, you can get a new wireless one at wal-mart for $20. Often wii sensor bars burn out because people put it directly on the tv instead of using the stand, the tv gets hot and the LED lights in the sensor bar burn out. If you want make sure that it's the sensor bar that's broken, get a video camera and video tape the sensor bar while it's plugged in and the wii is on, if you can't see four LED lights on each side then it's broken.
Jun 14, 2009 | Nintendo Wii Console
Wireless sensor bar needs setting up
http://www.nintendo.com/consumer/systems/wii/en_na/settingsSensorBar.jsp
The link above will show you how to set up a sensor bar
Bless you son for saying it's wireless lol :)
I hope this helps
Nov 13, 2008 | Nintendo Wii Console
The wire of the nintendo wii sensor is riped
well that basicle means that you cant play your wii because your wii motes cant register to the wii. wii sensor bars are pretty cheap and if you dont want the hassle of wires everywhere then you can just get a wireless sensor bars that are pretty pricy but not too bad. the downside of a wireless sensor bar is that the connection isnt that great and it drains battery life life CRAZY.
Oct 17, 2008 | Nintendo Wii Console
Wire of sensor bar pulled out by hoover,
Here's the best thing you can do:
Every Day Source has the Wireless Sensor Bar for Nintendo Wii for $4 with free shipping. Use code: WIIBARES .
Cheers!
Oct 16, 2008 | Nintendo BRAND AND SEALED NINJA REFLEX WII...
Wii sensor bar
possibly, or low batteries in the remote. Try placing the bar under the tv if its above at the moment, or vice versa if currently below. Also make sure sensor bar overhangs tv slightly too...
Mar 08, 2008 | Nintendo Wii Console
Problem with wiimote
the problem could be uv light, if its daytime make sure all the blinds are closed no extra lights are on near the sensor bar. if there is a glare on the screen at all it could be reflecting light to the wiimote as well. I've had that problem before myself, if that is not the case try moving closer to the sensor bar, make sure the sensor bar is connected correctly and then go to the system settings menu and calibrate the wii sensor bar and adjust the sensitivity, make sure you are not sitting at a wide angle from the snesor bar either, you can tip the sensor bar left and right in order to allow yourself a wider angle. also avoid using the nyko wireless sensor bar, it has a shorter range than the wired one that somes with the wii, mine came with a wireless on(used) and i just got a wired one and now it works much better. well I hope you find this info at least a little useful.
Feb 15, 2008 | Nintendo Wii Console
Can i make a nintendo wii work thru my ceiling projector and a digital sky box
Certainly! You should be able to connect the Wii's A/V cables to the inputs on your projector and place the Sensor Bar near the top of the projector screen. If the cable for the Sensor Bar isn't long enough, or if the cable gets in the way, you can purchase a wireless Sensor Bar.
http://www.gamestop.com/product.asp?product%5Fid=802612
This operates on batteries and can be placed as far away from the Wii as you like; the cable on the original Sensor Bar only carries power. Good luck!
Jan 19, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
379 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
